endyn catch can?
wht do you guys think of this? I like the fact that you dont have to empty it and all the oil that is caught in the can, can drain back to the motor
The new Endyn breather kit has been in development for over 4 years. It's designed to provide high performance Honda B series engines with efficient crankcase breathing, while eliminating excessive intake charge oiling and the detonation associated with it.
Regardless of piston ring condition, all Honda VTEC engines all suffer from excessive crankcase pressure at high power and RPM levels. This is caused by extreme piston speed, long camshaft timing events, and a PCV system that is completely inadequate at high throttle angles and low manifold vacuum levels.
Many of today's large displacement B series engines are based on new blocks where Honda deleted the breathing "can" (on the rear of the block), causing these engines really suffer from extreme crankcase pressure (frequently high enough to rush past the seals, blowing the spark plug wires off the plugs.) Pressures like these cause oil and other contaminates to severely degrade the quality of the mixture in the cylinders, reducing power and greatly increasing the possibility of detonation.
The new ENDYN breather kit uses a remote (modified) Moroso tank to separate oil vapors from the air that the engine inhales via the PCV valve, provides two large diameter block located outlets for excessive crankcase pressure, an (off-road only) breather filter to vent vapors to atmosphere, as well as a tank drain-back system to return excess oil to the crankcase under light throttle and deceleration.
The kit comes complete with the Moroso breather tank, Moroso breather element, (2) block vent tubes with aluminum gaskets, PCV valve and neoprene grommet, and all hoses and clamps for installation for a price of $164.00.
TIA
TIA
FuKc endyn. why do ppl listen to this guy???
whats with all these posts about catch cans? why do you need to start a new one? read through what everyone has done, make up your own mind. spend $1.25 on hoses and a soda bottle, or $50-100 for a fabricated plastic or aluminum can, or $164 to his special repackaged kit.
wow Tyson sorry to bother you sooo much but I was asking a question to those who have insight on the subject NOT to those who like to just bust people's *****
I do understand that there are different ways to run catch cans and different kind of catch cans being cheap or expensive
I was jsut asking if anyone had any fealings of whether or not having the oil that is caught in the can to drain back to the block was a good idea or not
as far as your comment about Endyn, Larry and his staff have been nothing but cool with me and as far as your experience with them I do not know
but seeing as thoguh you just freaked out for me posting on a mesage board about a general question (which I thought was the point of the message board) maybe it was your attitude going into the situation
PLUS I asked about one of thier products not thier business as a whole
so please if your going to be a dick just dont respond! thank you and have a nice day!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 »</TD></TR><TR><TD CLASS="quote">I was jsut asking if anyone had any fealings of whether or not having the oil that is caught in the can to drain back to the block was a good idea or not</TD></TR></TABLE>
how about contributing to one of these threads all withn the last day to week all about drain back systems. and yes, endyn kit is discussed in some of them.
https://honda-tech.com/zerothread?id=1243949
https://honda-tech.com/zerothread?id=1243464
https://honda-tech.com/zerothread?id=1227626
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">(which I thought was the point of the message board)</TD></TR></TABLE>
yes, there are messages in a message board, READ THEM FIRST before thinking your single thought is worth its own new topic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">FuKc endyn. why do ppl listen to this guy???
With you 100% on that Tyson. I have watched this clowns "saga" unfold for the last 6 years.
Starting with the supercharger that is 7+ years in the making.
What a crock of **** Larry is.
EK FLY
Oct 20, 2013 03:02 PM
HondaheadBigNick
Nov 9, 2008 07:19 AM
calib17a
Nov 12, 2005 11:20 AM
