climate control help
Old May 13, 2005 | 02:09 PM
mr0lg's Avatar
Default climate control help
yeah, i wanted amber lighting for my climate control (96-98). so i took out the bulbs, painted them, put them back in, pluged everything back in, and they dont light up.
no, the little wires on the bottom of the bulb are not covered in paint.
no, the bulbs arent bad
no, a fuse isnt blown
no, the dimmer switch isnt turned all the way down
i cant figure out why they wont light up..... they worked fine before i took em out.
anyone have any ideas?
Old May 13, 2005 | 02:10 PM
Bcuz's Avatar
Default Re: climate control help (mr0lg)
Maybe the paint you used is thick as *****, causing no light to eminate from the bulb.
Old May 13, 2005 | 02:15 PM
mr0lg's Avatar
Default Re: climate control help (Bcuz)
nah, its not thick at all...
before i put everything back together, i checked to see if the lights work...and they dont light up at all....
Old May 13, 2005 | 02:19 PM
Bcuz's Avatar
These bulbs can be tricky if your not familiar with them. When you put them in did you rotate them 90 degrees(clockwise).
Old May 13, 2005 | 02:22 PM
mr0lg's Avatar
mmm....these dont rotate....you just pop them in..
Old May 13, 2005 | 02:26 PM
Bcuz's Avatar
What kind of car, cuz. You know believe it or not, if try disconnecting and reconnecting your harnesses, it will sometimes make it work. I know this sounds completely retarded. One day I did an odyssey trans., it threw a code for no sensor ouput shaft reading. Pulled it out and put it back and it worked. Sorry for such a long *** reply but it helps to double check.
Old May 13, 2005 | 02:28 PM
mr0lg's Avatar
97 civic
ya ive disconnected, and connected the harness like 4 times, still nothin...
thanks for your help btw...
Old May 13, 2005 | 02:33 PM
Bcuz's Avatar
Sorry cuz. One more thing, maybe the paint was actually thin enough to creep in between the bulb and plastic grommet. Sorry dude ur working with a pollock, here.
Old May 16, 2005 | 06:02 PM
KtHaNxBai's Avatar
maybe the bulbs are not gettin any power bulbs might be too big and u dont realize it.
king29
Dec 4, 2008 03:21 PM
Midori Green
Oct 27, 2008 07:24 PM
shortlid
Apr 15, 2007 08:46 AM
cutelilvi3tboig
Nov 4, 2004 09:25 PM
