Tech question --- Cam chain replacement
Old May 13, 2005 | 02:00 PM
ronqqq's Avatar
Default Tech question --- Cam chain replacement
I have a 98 300 four trax that needs a cam chain..
How much technical trouble is this to do??
I have repaired many motors but never in on of these type of engines.
Is there anything I should know that will not be obvious??
What all should I replace when I do this other then the chain??
Will I need to buy a gasket set??
Thanks Ron
Old May 16, 2005 | 07:58 PM
ronqqq's Avatar
Default Re: Tech question --- Cam chain replacement (ronqqq)
No one have an answer???
Need help Please!!
Thanks Ron
Old May 18, 2005 | 09:08 AM
Racer_XX's Avatar
A friend and I changed a CCT on a CBRF4i which wasn't so hard if you have the repair manual. It was a bitch moving **** around just to get to the tensioner.
Old May 18, 2005 | 09:12 AM
EkEli's Avatar
rebmem roines
Default Re: (Racer_XX)
Search the net for a manual of it before you take it apart. You should be able to see whats all involved in it.
Here is one for bikes : http://www.bikechatforums.com/...art=0 I don't know where you could find a manual for a sport trac but I am sure someone has one online.
Old May 18, 2005 | 05:36 PM
ronqqq's Avatar
OK Thanks
I have a manual on the way.
Thanks for the info
Ron
Kellindal
Nov 30, 2004 01:02 PM
EX-JAY
Aug 20, 2004 09:56 AM
9200RPM
Dec 10, 2003 07:09 PM
