Ok any ideas?
Just to summarize, sept 04 i blew the h23a1, swapped in a jdm f22b, and blew the o2 sensor. I ran with the busted o2 from oct -> beg may .... due to low funds. Well I replaced the o2 sensor, and I can feel some gains back in acceleration, and the mpg are better but not as good as I feel they should be. My acceleration also feels choppy, and theres times where it chokes. However the only code being thrown is the knock sensor code (h23 ecu w/ knock sensor + jdm f22b w/o sensor). So whatever wrong isnt throwing a code. Im thinking maybe the cat could be either clogged or partially clogged, but not really sure. Anyone have an idea?
Symptoms
-Not perfect gas mileage
-Random choking in acceleration (Like not producing much power, and is taking a long time to go through the power band)
Symptoms
well since you are not running a knock sensor, the ecu response by retarding the timing and running richer
there are 3 ways of solving this that i know of:
1.f22b ecu
2.find a way to add a knock sensor on the block(best way to go)
3.install a different ecu(non-h-series) but that would require you to go w/ hondata
1.f22b ecu
So the lack of acceleration might be because of the knock sensor code being thrown, and the a/f ration getting messed up? and that might be the bad gas + accel problem? Can they add a knock sensor on a block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMF22B »</TD></TR><TR><TD CLASS="quote">So the lack of acceleration might be because of the knock sensor code being thrown, and the a/f ration getting messed up?yes it could be, unless the engine has another problem and that might be the bad gas + accel problem? yeah, it can be Can they add a knock sensor on a block? do a search, i think someone tapped a new thread for the knock sensor, it would be hard to do w/ the engine installed </TD></TR></TABLE>
it looks like this may be the problem from reading through other things... but I can't find a post on how to fix the problem
. I really dont wanna swap ecu's if possible
racingant
Sep 10, 2005 05:34 PM
