switching to mpfi
Old May 13, 2005 | 01:26 PM
tgjpwa's Avatar
Default switching to mpfi
does neone know how to switch a dpfi engine to mpfi cause the car is wired for mpfi but the motor is dpfi...help would b greatly appreciated...
Old May 13, 2005 | 01:44 PM
EP3_05's Avatar
Default Re: switching to mpfi (tgjpwa)
If the car is already wired for mpfi and the engine you have is dpfi you will need:
MPFI manifold
Si distributor
pm6, pm7, pg7, or pr4 ecu
This is assuming you are staying OBD0.
Old May 13, 2005 | 01:53 PM
Floored's Avatar
Default Re: switching to mpfi (91civic)
You should already have the ECU if the car was mpfi, you should only need MPFI intake manifold (w/ tb, injectors and fuel rail) and the Si dizzy. All the wiring should just clip right up.
Old May 13, 2005 | 03:42 PM
FalkenSiR's Avatar
Default Re: switching to mpfi (Floored)
If your car was wired for mpfi and had a dpfi engine in it, it wouldn't run. OF course if it is running then you have to wire something differently.
Old May 13, 2005 | 07:51 PM
crxdriver89's Avatar
Default Re: switching to mpfi (fast88std)
if the engine is dpfi, don't you have to make a block off plate on the head?? i'm not sure, but i have to do this when i swap in my sohc zc, which should be going in next week. i could be wrong, i guess it depends on what you have
Old May 13, 2005 | 09:04 PM
fourthgenhatchB17's Avatar
Default Re: switching to mpfi (crxdriver89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdriver89 &raquo;</TD></TR><TR><TD CLASS="quote">if the engine is dpfi, don't you have to make a block off plate on the head?? i'm not sure, but i have to do this when i swap in my sohc zc, which should be going in next week. i could be wrong, i guess it depends on what you have</TD></TR></TABLE>
Usually no such block off plate is needed. I *think* you might referring to the part on the head where a mechanical fuel pump was connected on the zc. Some sohc ZC's originally came carb'd.
Old May 15, 2005 | 03:30 PM
isekiEF9's Avatar
alot of work!!!!~
yo bj
10
May 27, 2009 02:50 PM
bigwill_2004
Sep 26, 2006 02:15 PM
Desert_Rex
Jan 19, 2005 01:30 PM
theharlequin
Apr 11, 2004 07:06 PM
low-tech assassin
Jan 6, 2003 02:43 PM
