Any new info on Power Sonic batteries?
Old Feb 4, 2002 | 06:15 PM
Piston Honda's Avatar
Default Any new info on Power Sonic batteries?
I was doing a little research on aftermarket batteries and came across the Power Sonic battery. It's weight and price looks very appetizing. I do not know anything about battery specs. So I ask the following questions.
1) Is there enough cca to start the car in 30F weather?
2) Is there enough power to power accessories (alarm, pw, etc.) with the car off?
3) Does it fit the stock tray w/o modification?
4) Possible to order it with post-type terminals like stock?
oh and sorry, i forgot this in my last post. The battery pictured in the FF squad pics is a Power Sonic PS 12180 w/ NB terminals They are about $60
Specs:
12v
17.5 Amp/hr
7.13x2.99x6.57
13lbs
for you geeks:
Nominal Capacity:
20 hour rate (900mA to 10.50 volts) 18.0 AH
10 hour rate (1700mA to 10.50 volts) 17.0 AH
5 hour rate (3000mA to 10.20 volts) 15.0 AH
1 hour rate (12A to 9.00 volts) 12.0 AH
Energy Density (20 hour rate) 1.54 Watt-hours/cubic inch 94.0 Watt-hours/l
Specific Energy (20 hour rate) 16.5 Watt-hours/pound 36.6 Watt-hours/kg
Internal Resistance (Fully Charged Battery) 15 milliohms (approx.)
dave w
[Modified by Piston Honda, 7:16 PM 2/4/2002]
Old Feb 4, 2002 | 06:17 PM
B2FiNiTY's Avatar
Default Re: Any new info on Power Sonic batteries? (Piston Honda)
That looks good. Free up some space too.
Old Feb 4, 2002 | 07:03 PM
nsxtcjr's Avatar
New User
Default Re: Any new info on Power Sonic batteries? (B2FiNiTY)
Check into the Odyssey battery. Great product. Just as small.
Old Feb 4, 2002 | 07:07 PM
GQ 05YellowEVO8's Avatar
Default Re: Any new info on Power Sonic batteries? (nsxtcjr)
Where can I get one?
Old Feb 4, 2002 | 07:36 PM
jgale's Avatar
$60 sounds pretty good. I just picked up a 13.5lb Dynabatt for over $120.
Old Feb 4, 2002 | 08:37 PM
nsxtcjr's Avatar
New User
Default Re: Any new info on Power Sonic batteries? (TODA RACING)
http://www.odysseyfactory.com/odybuy.htm
Old Feb 4, 2002 | 10:19 PM
ITR#132's Avatar
Would they happen to have the battery with posts that will fit our stock wiring? Or is there a battery post kit that they sell separately? thanks
Old Feb 4, 2002 | 11:06 PM
sutats's Avatar
How much is an Odyssey battery? Cheers!
Old Feb 5, 2002 | 04:05 AM
Default Re: Any new info on Power Sonic batteries? (sutats)
EDIT - Just saw some pricing from Baker Precision.
PC680 - $148.00
PC925 - $172.95
At that price, I could look at the Dyna-Batt or even Spoon for a few dollars more. So back to Power Sonic...
[BeforeEdit]
Which Odyssey battery suits out needs? On the other post [ https://honda-tech.com/zerothread?id=110801&page=2 ] there was a bit of discussion as to which Odyssey battery suits out needs. I.E. the PC680 or the PC925.
Anyways, here is a link to those that understand battery specs.
http://www.odysseyfactory.com/specs.htm
[/BeforeEdit]
[Modified by Piston Honda, 5:10 AM 2/5/2002]
Old Feb 5, 2002 | 06:41 AM
rolow's Avatar
whats the weight of the spoon?
how about the factory battery?
Old Feb 5, 2002 | 06:48 AM
HX_Guy's Avatar
Default Re: Any new info on Power Sonic batteries? (rolow)
OEM size battery (Autozone brand) is 29 LBS
Old Feb 5, 2002 | 02:27 PM
I would have to rule out Spoon due to its price. Basically, my budget is +-$20 from the cost of the OEM battery. If the Power Sonic fits the bill, that will be my choice. Otherwise the OEM battey is my fallback.
Perhaps I will be the ginea pig and purchase it and report back to those interested.
Old Feb 5, 2002 | 02:34 PM
yoshi234's Avatar
I shoot brides
yes, please do and report back
while you're at it could you also be a guinea pig for the earthing system?
yshi - who still has the honda batt from his EF sitting in the garage
Bboy_Trevstuh817
Dec 8, 2006 03:33 PM
Lip
Audio / Security / Video
Apr 5, 2006 01:55 PM
