Fuel pump help
Old May 13, 2005 | 01:00 PM
Jowee's Avatar
Default Fuel pump help
I replaced my 255 in the hatch with a stocker and ended up getting this metal ring stuck in the line. I had to forcefully remove it which caused it to kinda bend out of shape. Do I need to order a new ring or would it be ok?
Old May 13, 2005 | 01:21 PM
chameleon's Avatar
Default Re: Fuel pump help (ITR 98 1162)
you should be ok without it, i broke mines off also, but easily put it back on its not needed for anything its like a seal for the rubber line but it comes off so easily if your not careful just use a good clamp when you get the rubber line on and u should be good.
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
mellbell
Nov 11, 2008 12:38 AM
JLHDOHC
Apr 30, 2006 04:18 PM
nathanie1
Jun 27, 2005 07:06 PM
MarkosMotorsports
May 24, 2004 06:58 PM
