new idea for crank pulley removing tool
Old May 13, 2005 | 12:59 PM
dfoxengr's Avatar
Default new idea for crank pulley removing tool
thinking of having a local shop cut me one with his laser
it would help you remove the crank pulley while your transmission is off of the motor, either in the car still or on a stand.
it is a plate that you attatch to 2 of the flywheel bolts and put a 1/2 drive ratchet in the center. this gives leverage and stops the crank from spinning
input, comments?
Old May 13, 2005 | 01:10 PM
blackwagon's Avatar
Default Re: new idea for crank pulley removing tool (hybridvteceg)
whats wrong with a chain wrench?
Old May 13, 2005 | 01:40 PM
dfoxengr's Avatar
Default Re: new idea for crank pulley removing tool (blackwagon)
nothing, this seems simpler and is another option
Old May 13, 2005 | 02:17 PM
Just Checking In's Avatar
Sounds like something you could make look nicer and fit better then the flywheel stops that are out there if you make it just for a single motor series. Just an fyi to anyone needing a flywheel holder for a b series, you can get one that works really well thats intended for old VW beetles from Bap Import parts. They are similar to what you are describing to make.
Old May 13, 2005 | 03:50 PM
dfoxengr's Avatar
Default Re: new idea for crank pulley removing tool (Just Checking In)
yeah i think mine is a very good idea..anoyone else care to comment?
Old May 13, 2005 | 04:12 PM
splitime's Avatar
Just toss the flywheel back on with 2 bolts... and put a screw driver through it
Alot cheaper than something being made.
Old May 13, 2005 | 04:47 PM
dfoxengr's Avatar
Default Re: new idea for crank pulley removing tool (splitime)
i like things simple tried that sort of thing before and you cant wrench down on it very well by yourself with that method
Old May 13, 2005 | 10:14 PM
buckfittyone's Avatar
thats a damn good idea,i actually thought about that this morning,the motor im taking apart was from an automatic ,it had a driveplate instead of a flywheel i tried the screwdriver jamming method and that didnt work for ****,the driveplate holes are all bent up now.
a simple plate with 2 holes in it is a much cheaper solution, cause im not down with paying $80 for the moroso tool either go for it make 2 and sell me one for mad cheap
Old May 14, 2005 | 03:08 AM
1fastVX's Avatar
Default Re: new idea for crank pulley removing tool (buckfittyone)
Here is a crank pulley holding tool that is cheaper than the Moroso unit and is nicer.
http://www.thetoolwarehouse.net/shop/SP-60100.html
John
Old May 14, 2005 | 08:30 AM
dfoxengr's Avatar
Default Re: new idea for crank pulley removing tool (1fastVX)
thats nice and all but mine goes on THE FLYWHEEL SIDE
lol, alittle different
Old May 14, 2005 | 09:59 AM
RCautoworks's Avatar
Yeah, but for the price your gonna pay for materials and the cutting, just spend 40 bucks on the one tool that holds the crank pully, you can use it when the trans is on to.
Just my 2 cents
Old May 14, 2005 | 10:52 AM
Default Re: new idea for crank pulley removing tool (90blackcrx)
yeah but materials and cutting wouldnt cost more than like 20 bucks if that.whats up hybridvteceg you gonna get one made cause i seriously need one too
Old May 14, 2005 | 10:56 AM
dfoxengr's Avatar
im actually thinking about making these to sell on here since im a sponsor. post here if you want one. but no pricing or selling will be discussed in this thread here.
https://honda-tech.com/zerothread?id=1234918
Old May 14, 2005 | 10:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Just toss the flywheel back on with 2 bolts... and put a screw driver through it
Alot cheaper than something being made.</TD></TR></TABLE>
A better way is, use an open end wrench with a close end on the other side, bolt that to the engine and have the open end hold the clutch dowl pins.
Old May 14, 2005 | 11:50 AM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">thats nice and all but mine goes on THE FLYWHEEL SIDE
lol, alittle different</TD></TR></TABLE>
I know this sounds like a dumb question but is there any advantage to your design?
Thanks
Old May 14, 2005 | 12:32 PM
dfoxengr's Avatar
Default Re: new idea for crank pulley removing tool (EKhatch)
like ive said, its simply a different option. i always find myself needing something like this when i am taking motors apart and such, so i figured others would too...
Old May 14, 2005 | 01:04 PM
cua0's Avatar
why not just weld a 52mm nut to the end of a bar, that's all the 'honda specialty tool' is
Old May 14, 2005 | 01:59 PM
notoriousB's Avatar
Default Re: (cua0)
here's my flywheel-side crank pulley bolt removal tool
(the cats were not impressed either)
Old May 14, 2005 | 04:41 PM
dfoxengr's Avatar
Default Re: (cua0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">here's my flywheel-side crank pulley bolt removal tool
(the cats were not impressed either)</TD></TR></TABLE>
its actually 50mm, and it is FOR THE FLYWHEEL SIDE lol
geez, please ready my original post. lol
haha
Old May 15, 2005 | 09:25 PM
dfoxengr's Avatar
Default Re: (hybridvteceg)
anyone else?
Old May 15, 2005 | 10:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">anyone else?</TD></TR></TABLE>
Honestly, I know you want to hear something different but I really gave your idea a shot, I say save your money. There are already tools out there at a reasonable price to do this job.
And yes these tools hold the pully from spinning, but I would see more of a demand for this because sometimes people do timing belt jobs and the trans is still on.
Basically that tool can be used with the trans on or off, your tool has to have the trans off.
Make a piece that locks the cam gears into place and I would buy that.
Thats what I think, take it for what its worth
Old May 17, 2005 | 05:58 AM
JDMCRX's Avatar
Default Re: (90blackcrx)
find a big bolt that fits that center of the pulley then grind the center out so u can get ur socket threw then weld a bar onto that nut and then u can hold the crank and put ur socket threw the center and remove the pulley bolt
Old May 17, 2005 | 08:59 AM
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">find a big bolt that fits that center of the pulley then grind the center out so u can get ur socket threw then weld a bar onto that nut and then u can hold the crank and put ur socket threw the center and remove the pulley bolt</TD></TR></TABLE>
He already know how to do that, he is not asking that.
Do people not even read the first statment by the posters, just read the topic and jump into these things ?
Old May 17, 2005 | 11:29 AM
JDMCRX's Avatar
Sorry guy was at work not supposed to be on here i glanced at it and posted ill read it lol
Old May 17, 2005 | 12:53 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Do people not even read the first statment by the posters, just read the topic and jump into these things ?</TD></TR></TABLE>
im pretty sure 90% of the kids on here are illiterate too.
