Going from ITR cams to CTR cams?
Will it make a difference going to dyno from ITR cams to CTR cams and JG 65mm throttle body? im talking about power that im going to gain coming from ITR cams considering everything is the same except the throttle body and the CTR cams and basic bolt ons?
skunk2 manifold...but the ITR cams is from 98, the i switched to 01...which is CTR cams...so what do u guys think? thanks much...
more feedback
more feedback
No, I dont think its worth it. I think the CTR intake cam has a wee bit more duration and the exhaust cams are the same. Someone correct me if Im wrong...
Any cam that can still use stock springs are not big enough IMO.
In all motor, Go Big or Dont go at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem »</TD></TR><TR><TD CLASS="quote"> I think the CTR intake cam has a wee bit more duration and the exhaust cams are the same.
3 degrees more duration
I have ctr cams in my car and they dont feel like anything special they feel jus like gsr's or b16's im jus using them till i can get my rocket m22. But i would save your money keep the itr cams and buy something bigger when u have the money
ok since the CTR is not the greatest out there...what will be the best i can buy considering i will change the springs and so i wont have a valve float...but i will not change the compression ratio...let me know...thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_FED_DC_2 »</TD></TR><TR><TD CLASS="quote">I have ctr cams in my car and they dont feel like anything special they feel jus like gsr's or b16's </TD></TR></TABLE>
what kind of engine management are you using?
vtecdc2
Sep 2, 2002 07:52 PM
