high comp/ 95mm stroke ls/vtec, who makes block plate for this?
i've got ls vtec with gsr head . eagle stroker kit with 12:1 c/r pistons... my engine is over bored half a mil. and a 95mm stroke. think my c/r will be 12.5:1 to 13:0
im putting engine togeather this weekend to check all clearances im going to clay it .... i think i might need a block plate.
who makes block plates, for these setups. ive searched quite a bit in here. any help would be great. thanks guys
Half of the stroke + rod length + piston compression height = less than 212mm your ok,more than 212mm you need deck plate and longer sleeves.Valve to piston clearance (claying) isn't the issue.The eagle catalog says if a particular kit needs a deck plate.
Glenn
Glenn
http://www.erlperformance.com/...1.pdf
This is the only one I've seen that I'd trust, but it's not cheap. You may as well just buy a Dart B20+ block, that's what I did. 95mm stroke with 6" rods for about a 1.6 ratio and JE stocks the pistons.
ryguy2588
Jan 8, 2013 08:10 PM
mskibbz-T
Nov 1, 2002 12:39 PM
CHEETAH
Oct 18, 2002 12:14 PM
