Easiest way to remove the gray trim.
Old May 13, 2005 | 12:59 AM
GetawayInMoscow's Avatar
Default Easiest way to remove the gray trim.
I need to install a CD player tomorrow and Im going to have to remove the gray trim that goes around the steering wheel to the climate control and factory CD player. I looked briefly and didn't see any screws so I was wondering if there is a trick to it. I don't really want to break anything.
Old May 13, 2005 | 01:03 AM
eg686's Avatar
Default Re: Easiest way to remove the gray trim. (GetawayInMoscow)
the only way is to take out the dash and unscrew all the bolts.
I dont think you need to remove the grey trim right?
Old May 13, 2005 | 02:07 AM
longbeachpurplecivic's Avatar
Default Re: Easiest way to remove the gray trim. (dchan86)
if youre gonna install a new radio then you dont need to remove the grey trim. unless youre doing some custom stuff..
Old May 13, 2005 | 08:27 AM
Default Re: Easiest way to remove the gray trim. (longbeachpurplecivic)
How is it held in there then? I need to take the stock one out. I figured something's got to be holding it in...
Old May 13, 2005 | 08:32 AM
duggy's Avatar
take off the panel where your cigarette lighter and ashtray are. under there, is 2-3 screws that hold the radio
Old May 13, 2005 | 08:38 AM
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">take off the panel where your cigarette lighter and ashtray are. under there, is 2-3 screws that hold the radio </TD></TR></TABLE>
Cool thanks!
danomatic93
12
Feb 7, 2013 07:50 AM
96si-tuner
Audio / Security / Video
Jan 18, 2005 03:06 AM
wizard920
Aug 22, 2004 03:22 PM
seer_claw
Mar 1, 2004 05:28 PM
Qikcivic
Mar 29, 2003 10:28 AM
