Just took out heater core, i bent up the pipes that lead coolant. Is this a bad thing?
Will this cause me any problems for when i put the heater core back in and the car back together? The hoses for it were so seized that it took alot to get them off, but in that process i ended up bending the pipes. Of i straighten them out a little will this cause any problems later on with heat?
the only problems i see are if they are kinked. if the bend isnt too bad it should be ok. becareful bending them back tho, you could cause them to snap.
NatedoggAZ
Jun 25, 2014 05:30 AM
