wiring field sfc in 98 gsr will post diagram
ok im wiring a field vafc into my 98 gsr. i wired it accoring to the diagrams that i found...( i had to look at a bunch of them to figure out the right wires ) and the controller is not getting power. i hooked the wire up for the VTM ( which i dont know what its for) and taped off the other wire like the diagram says. i got a check engine light but no power on the controller. after hooking the VTM wire back i started the car again, still no power but no check engine light this time. i hooked the ground wire up to the chassis behind the ecu and i got the paint off the ensure a good ground. Does the ground need to hook to the ground on the ecu or should the ground to the chassis be okay?? im not getting power...
the diagrams ive been using are the H4 diagram here:
it takes a second to load cuz its pdf
http://www.fastjapcars.com/sfc_manual.pdf
bump... okay i think i do have all the wiring correct... exept i dont know what the vtm line is for... can anyone tell me? and does the ground wire need to be grounded to the ecu or can i just ground it to the chassis?
yeah turns out the sfc is fried.. i bought it off ebay for 120 bucks.. i got ripped... if anyone needs the harness let me know
GetawayInMoscow
Audio / Security / Video
Dec 24, 2006 04:34 PM
