My steering wheel will not straighten out after i complete a turn.....
Old May 12, 2005 | 07:50 PM
cnyej1's Avatar
Default My steering wheel will not straighten out after i complete a turn.....
Ok this is on my beater civic... anyhow I knew that there was a specific part that would cause this but I have forgotten what it is, and well this is a pretty annoying thing.
In a non broken car when you turn your steering wheel when going around a corner etc your wheel will straighten itself back out after you complete the turn. On my civic it doesnt do this, it will l stay in the exact position it was turned at. What in the hell is broken???
Old May 13, 2005 | 07:02 PM
cnyej1's Avatar
Default Re: My steering wheel will not straighten out after i complete a turn..... (cnyej1)
Anyone??
Old May 13, 2005 | 07:10 PM
OneFire's Avatar
You need an alignment and toe adjusted. I asked this question a few days ago and recently got a alignment and everything works the way it's suppose to If you're on budjet you could atempt to adjust the toe yourself Hope this helps
Old May 13, 2005 | 07:15 PM
cnyej1's Avatar
Default Re: My steering wheel will not straighten out after i complete a turn..... (SOHC_Ek)
Cool thankx... I thought the alignment would help, but I wasnt sure if there was just something broken.... I couldnt remember.
Old May 13, 2005 | 07:20 PM
civic_fan's Avatar
check your bushings and balljoints....if you havent done anything to damage the car before this started happeneing, youve most likely got a dead bushing/balljoint.
Old May 13, 2005 | 07:21 PM
Kamin's Avatar
its actually caster that centers your steering wheel.
Old May 13, 2005 | 07:43 PM
Turbo E's Avatar
Default Re: My steering wheel will not straighten out after i complete a turn..... (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">its actually caster that centers your steering wheel.</TD></TR></TABLE>
...so he needs an alignmet
Old May 13, 2005 | 08:28 PM
Kamin's Avatar
Default Re: My steering wheel will not straighten out after i complete a turn..... (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">...so he needs an alignmet </TD></TR></TABLE>
lets hope its just an alingment
FWD cars dont really have much caster adjustment. probably bushings or worse.
Old May 13, 2005 | 08:30 PM
cnyej1's Avatar
Ehhh Ill take a look under there.... I have a full 94 coupe parts car...its my old car that I wrecked..... this is just my beater...215k of fury.
Old May 13, 2005 | 10:38 PM
civichatch95md's Avatar
my friend just had the same problem in a 97 ex. it was a bad steering rack. Only thing he had happen was it wouldnt return to center at all. But that might be a worst case.
ThatGuy4life
Aug 20, 2007 08:05 PM
jisu009
17
Jul 21, 2005 10:26 AM
sohcvtec66
Apr 15, 2004 10:32 PM
Essence of Chicken
Nov 13, 2003 09:21 PM
GSblueRacing
May 2, 2003 01:03 PM
