shifter rattle...
Old May 12, 2005 | 06:02 PM
1.8's Avatar
1.8
Default shifter rattle...
my shifter rattles when i go over 4.5 rpm. it's not hitting anything. i've gone under the car 3 times and tightened everything over everytime. what could be the problem? it's a DC short shifter...
Old May 12, 2005 | 06:06 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: shifter rattle... (1.8)
when it's in gear or in nuetral?
Old May 12, 2005 | 06:09 PM
Lmgrcivic's Avatar
Default Re: shifter rattle... (Screwtape:)
change the rubber peice that goes on the shifter
Old May 12, 2005 | 06:11 PM
Turbo_y8's Avatar
Default Re: shifter rattle... (Lmgrcivic)
it could be your exhaust if your jacking the car up unevenly it moves the exhaust around when your car is up on one side if you know what i mean mean did it too i just heated up the hanger and bent it prob solved
Old May 12, 2005 | 06:13 PM
1.8's Avatar
1.8
Default Re: shifter rattle... (Honda_project98)
when it's in gear....
rubber piece has already been changed to the ES bushings....
can't be my exhaust because i also double checked when i went to the exhaust shop. it was lifted evenly...
anymore ideas? should i relube the shifter? will that help?
Old May 12, 2005 | 06:17 PM
Bimmerman's Avatar
mine was like that and it turned out to be the shift **** rattling, I had a all metal ****
Old May 12, 2005 | 06:31 PM
hondaboy4life's Avatar
Default Re: shifter rattle... (Bimmerman)
mine rattled a lil too, it was because of the little like plastic or metal ring on top of my shift boot, hitting the shifter rod or whatever u wanna call it. Dunno if that'll help but o well, i try
good luck
Old May 12, 2005 | 08:16 PM
1.8's Avatar
1.8
Default Re: shifter rattle... (hondaboy4life)
it can't be the **** because i just changed it into a skunk2. before that i had a stock one. both rattled.
Old May 12, 2005 | 08:35 PM
duh blacksheep's Avatar
resonant frequency vibration?
Old May 12, 2005 | 08:49 PM
jeffk182's Avatar
Tighten the bolt that holds the shifter to the linkage...did that and I have no more rattle
rams2k4rm
Sep 11, 2006 07:49 AM
erikiksaz1
Mar 28, 2005 01:51 PM
Gimpo
Dec 26, 2004 11:51 AM
crxzc
Jul 2, 2002 05:09 AM
charjacq
Apr 27, 2002 12:32 PM
