1992 JDM Foglight Wiring Question, No 1-pin Connector
Old May 12, 2005 | 05:34 PM
BlueIntegraBoy's Avatar
Default 1992 JDM Foglight Wiring Question, No 1-pin Connector
I am pretty sure my EG didn't come prewired for the foglight. It says look for a 1-pin plug with a blue/red wire near the headlight. I checked all over and didn't see it. I am pretty sure I don't have the 1-pin connector near the fusebox. If I wanted to make an OEM working foglight, do I just need to run one wire from the cabin to the engine bay that connects the interior harness to the exterior harness? Because all the other plugs should plug in, such as the 5-pin plug that goes to the foglight switch, the 7-pin plug that goes to the light switch, and the dimmer connector thing?
I've searched for an hour and found out other people didn't have these connectors. I wonder if it's simple like that. My fogs are on the way, but I like to read in advance so I understand the procedure. If anybody who has an EG with OEM foglights and DID NOT have the 1-pin connector with the blue/red wire can answer this question, I would apprecaite it very much. TIA.
Old May 12, 2005 | 08:27 PM
longbeachpurplecivic's Avatar
Default Re: 1992 JDM Foglight Wiring Question, No 1-pin Connector (BlueIntegraBoy)
just wondering.. how much time did you put in to look for those connectors?? i got a 93 civic and i found them, but it was pretty well hidden i suppose.
Old May 12, 2005 | 08:52 PM
dohcdelsol's Avatar
Default Re: 1992 JDM Foglight Wiring Question, No 1-pin Connector (longbeachpurplecivic)
im in the same ******* boat...........
i hooked up my depo lights... exactlly how it says in the instructions......
my relay clicks and all but lights dont light up... wtf!
all grounds good, the outside harness connects the the inside and all but it doesnt hook up
ANYONE WITH AN EG WITH THE DEPO LIGHTS HELP ME OUT!!!!!
and bump for the creater too
Old May 12, 2005 | 08:58 PM
Default Re: 1992 JDM Foglight Wiring Question, No 1-pin Connector (dohcdelsol)
i dunno but the guy created the post cause he cant find is pin connectors, but you have yours all hooked up and dont work... trace back your steps
Old May 13, 2005 | 12:40 AM
I dont have the connector. I looked where the washer reservoir would be. Nothing. I looked near the headlight, nothing. I even looked inside the wire loom and I don't see a blue/red wire.
Old May 13, 2005 | 12:42 AM
My foglights are OEM, so the Depo instructions wouldn't work. I have the JDM harness. I want to hook these lights up as if stock and want to use the OEM foglight switch.
longbeach, where was your connector hidden? My washer reservoir is gone and I pulled the fender liner to only see the connector for the reservoir.
Old May 13, 2005 | 01:27 AM
i had to cut some tape off one of the FAT harnesses along the wash reservoir, it should a brown clip in there, i never knew that it DIDNT come in some civics.. was there a particular yr or month or model? and under the dash its those two wide connectors, i believe the fuse box is hooked up to it? i dont remember, do you know what im talking about?
Old May 13, 2005 | 01:28 AM
my brother took it off my ride and slapped it on his 93 hb dx, he had the clips, maybe 92 didnt come with it? i dunno
Old May 13, 2005 | 01:30 AM
Haha, I dont have my fogs yet, on the way from Japan. I decided to get a head start to locating all the plugs. I tried looking for the engine bay plug. I'll look in the wire loom and see if it's there. I haven't attempted the cabin plug yet.
Old May 13, 2005 | 01:35 AM
the cabin plug was a f***n pain in MY ***. if youve got the honda intructions then you hsould no probs finding it
Old May 13, 2005 | 01:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longbeachpurplecivic &raquo;</TD></TR><TR><TD CLASS="quote">the cabin plug was a f***n pain in MY ***. if youve got the honda intructions then you hsould no probs finding it </TD></TR></TABLE>
So hopefully the brown connector is in the wire loom. Inside the engine bay or behind the fender? I've taken my dash out before. If it requires it, then I'll do it again.
Old May 13, 2005 | 02:01 AM
its inthe engine bay. where you were talking bout. no need to take off the dash, just a little tight under there thats all.
Old May 13, 2005 | 02:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longbeachpurplecivic &raquo;</TD></TR><TR><TD CLASS="quote">its inthe engine bay. where you were talking bout. no need to take off the dash, just a little tight under there thats all.</TD></TR></TABLE>
So look inside the wire loom in the engine bay near that fuse? I kind of looked inside, but didn't cut the tape portion. Cross my fingers, I look tomorrow morning.
Old May 13, 2005 | 12:51 PM
Well, after looking, I dont have the connector inside the cabin. I think I'll just run a wire from the engine bay to the cabin.
Old May 13, 2005 | 06:45 PM
naw not near that fuse on the other side.. you mentioned you checked aorund the fluid reservoir
Old May 13, 2005 | 09:32 PM
I don't have it. My friend has a 94 DX coupe and I immediately found that wire taped behind the driver's light. I don't have it. I am just going to run the power wire.
Old May 13, 2005 | 09:38 PM
t0ekn3e's Avatar
whoa what pin is this have some jdm headlight and i ran striat to battery and switch with a fuse
Old May 13, 2005 | 09:51 PM
Default Re: (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">whoa what pin is this have some jdm headlight and i ran striat to battery and switch with a fuse</TD></TR></TABLE>
Supposedly only 94-95 Civics were prewired for fogs. They had a 1-pin connector with a blue/red wire that ran from the engine bay to the interior. Mine does not have it. I have a complete engine bay harness and cabin harness. The only thing I would be missing is the wire that goes from the engine bay to inside the car. I guess I'll wire everything up as the instructions say and run the single wire through the firewall.
Old May 13, 2005 | 09:57 PM
t0ekn3e's Avatar
damn them 94-95 i got a 92 also
Old May 13, 2005 | 10:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">damn them 94-95 i got a 92 also</TD></TR></TABLE>
Yeah, going to hook them up tomorrow since I got them today from Japan. I hope my plan works.
Old May 13, 2005 | 11:54 PM
CHiNkStEr's Avatar
i'll go try and look and mine and take some pics.
Old May 14, 2005 | 02:59 AM
Default Re: (*****StEr)
i had a 93 it came with it . good luck hope it works with you as well mang let us know
Old May 14, 2005 | 03:00 AM
lol hes talking bout foglights yo, reading owns you!!
Old May 14, 2005 | 03:05 AM
Default Re: (longbeachpurplecivic)
K boys, I got my fogs today and it looks very simple to install. A lot less work than the Honda Accessories instructions show. The harness looks more like the Depo harness where it doesn't connect to the light switch nor the dimmer.
Old May 14, 2005 | 05:59 AM
egsleepercivic's Avatar
on both my 94 ex and my 92 si there is a 1 or 2 wire plug taped up next to the driver side shock tower harness is this for the fogs I really have know clue and would like to know?
