S2K seats into 98 Prelude
Old May 12, 2005 | 05:15 PM
st3alth's Avatar
Default S2K seats into 98 Prelude
I need to know if anyone has done it on these forums yet? With those seats into that particular honda...
If so, how?
Thanks!
Old May 12, 2005 | 05:32 PM
lewdude's Avatar
Default Re: S2K seats into 98 Prelude ([ S7H ])
Send a PM to c61lude. Supposedly he has done it.
Old May 12, 2005 | 07:25 PM
spoolinlude's Avatar
I live under a rock
Default Re: S2K seats into 98 Prelude (lewdude)
Ian did it like 2 years ago...... maybe longer
he cut the brackets off his stock seats and welded them onto the s2000 seats...... done deal. looks good
Old May 12, 2005 | 08:22 PM
prelude1897's Avatar
Default Re: S2K seats into 98 Prelude (spoolinlude)
This isn't my car, I got this from PO.com
S2k seats with stock S2k brackets and sliders
Hardware Needed:
(x6) 7/16" -14 x 1.25 hex bolts
(x6) 7/16" lock nuts
(x2) 10mm x 1.25 x 1.25 bolts
(x4) 1/2" nuts
(x1) 3ft of 3/16" x 1.5 steel stock
(x6) stock mounting bolts
(x4) 7/16" washers
Tools:
dremel
drill and 7/16" and 10mm bits
jig saw / hack saw
wd40 (drill bit lube)
wrenches/sockets
Overview:
S2k seats sit ~ 2" lower then stock seats
to raise the seats use the steel stock to make six brackets
the smaller brackets are for the front mounts
the larger brackets are for the outer rear mounts
Bracket construction:
to construct the front brackets cut the steel to length (depends on desired seat height) and drill a lower 10mm (stock bolt diameter) hole
the upper hole needs to be offset from the lower an amount equal to the height u want to raise the front of the seat; this is a 7/16" hole
the rear bracket size will depend on the height of the seat
the higher it is, the shorter the rear bracket
follow the procedure for the fronts to fabricate the rears, drill two holes, 10mm and 7/16"
to help the drill do its dang dang use penetrating oil, or wd40
also progressivelly drill the holes from small to large to speed things up
i sanded and painted the brackets to prevent rust, thats your call if u want to do that
Install:
start with the rear inside mount
this is the only hole on the stock S2k brackets that will need to be enlargened
place a 1/2" nut (raises rear of seat) btwn the floor and the seat bracket, then a 10mm x 1.25 x 1.25 bolt with a washer through the top of the bracket
the outside rear mount is where the long bracket is used
align the floor’s mounting hole and the smaller bracket hole, then the larger hole with the S2k's bracket hole
secure the stock floor mount to the bracket with a stock bolt
place a 7/16” lock nut below the fabricated bracket, then a1/2" nut between the fabricated bracket and the S2k seat’s bracket, then a 10mm x 1.25 x 1.25 bolt with a washer through the top of the S2k bracket
the front brackets bolt up to the stock floor mounts using a stock bolt through the smaller diameter hole in the fabricated bracket
the fabricated bracket then bolts up to the seats bracket with a 7/16" -14 x 1.25 hex bolt and a 7/16” lock nut
driver side / pasenger side of drivers seat
the distance between the S2k front mounts is ~3/4" wider then the distance between the stock floor mounts, one of the fabricated front brackets needs to be angled to make up for the diffrence
also the angle of the S2k seat front mounts is lower then the stock floor mounts, the S2k brackets need to be bent down
finally connect the seat belt indicator plugs beneath the seat
Results:
better brackets could be made by bending the steel to raise the rear of the seat
u could also bend the front brackets to match the lower angle of the S2k mounts
Old May 12, 2005 | 09:43 PM
PrettyLude's Avatar
man them seats look good brian, i wish it was my car, but in red though
Old May 12, 2005 | 10:39 PM
st3alth's Avatar
Default Re: (PrettyLude)
that DIY doesnt look like the safest way to mount seats.. but 10/10 for effort tho...
however it didnt resolve the issue of reclining foward(when ppl want to get into the back seat) as it was originally designed for the s2000?
Coz I realise I can just get custom rails made up.. but it wont resolve the issue as mentioned above...
Modified by [ S7H ] at 12:55 AM 5/13/2005
Old May 13, 2005 | 03:00 AM
ludedude00's Avatar
Default Re: ([ S7H ])
the seats are expensive though, one seat runs you $4,500
Old May 13, 2005 | 04:43 AM
st3alth's Avatar
I already have the seats... JDM model
Old May 13, 2005 | 05:44 AM
Default Re: (ludedude00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedude00 &raquo;</TD></TR><TR><TD CLASS="quote">the seats are expensive though, one seat runs you $4,500 </TD></TR></TABLE>
Unless you see people selling them used here. I've sold S2000 seats anywhere from $400-$700
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">man them seats look good brian, i wish it was my car, but in red though</TD></TR></TABLE>
This isn't my car. This is just a write-up I saw on PO.com
Old May 13, 2005 | 05:55 AM
SpeedMachine's Avatar
Default Re: (prelude1897)
4500 dollars my ***. thats means what the s2k is only worth 12k without the seats. WTF
Old May 13, 2005 | 01:33 PM
SUB-0 H23's Avatar
Default Re: (SpeedMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedMachine &raquo;</TD></TR><TR><TD CLASS="quote">4500 dollars my ***. thats means what the s2k is only worth 12k without the seats. WTF</TD></TR></TABLE>
LOL
Old May 13, 2005 | 06:35 PM
st3alth's Avatar
anyone know if swapping seat pans with s2k ones can work?????
Old May 13, 2005 | 09:14 PM
ludedude00's Avatar
okay really? 4,500 dollars when you buy it from honda ******. just goto your closest dealership and ask the parts department i cant stand when people try to get smart with me on **** i know is a ****** fact
Old May 14, 2005 | 03:28 AM
xbn83's Avatar
Total the parts then yall will have answer: http://www.hondaautomotivepart...=SEAT
Old May 14, 2005 | 05:15 AM
st3alth's Avatar
Default Re: (xbn83)
cmon guys back on topic... someone must know something..
sicky
Mid-Atlantic (Sales)
20
Oct 24, 2008 01:52 AM
Jap_Spec_Imports
Aug 15, 2008 02:53 PM
hamadiscool
Jul 20, 2006 04:17 PM
EM199dcs
Mar 23, 2006 02:08 PM
Mugen Powered EP
Dec 20, 2005 07:53 AM
