antenna
Old May 12, 2005 | 05:11 PM
hondaracing1's Avatar
Default antenna
how do you replace the stock antenna mine broke and i cant figure it out
Old May 12, 2005 | 05:37 PM
Bond's Avatar
Default Re: antenna (hondaracing1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracing1 &raquo;</TD></TR><TR><TD CLASS="quote">how do you replace the stock antenna mine broke and i cant figure it out</TD></TR></TABLE>
Take out the two screws on the roof. Pull the cap up and away from the antenna. Next remove your car stereo. Then disconnect the antenna from the head unit. Tie a long string onto one end of the antenna cable. Now I would suggest pulling it out from the roof. Pull it out and make sure the string is still attached. Now tie the new antenna cable to the string and feed it through to the back of your stereo.
^^^^this is how to replace your antenna cable. To replace the actual antenna then unscrew the same two bolts from the roof. Just pull it out enough that you can disconnect the cable from it. Do the reverse for instillation.
xJDMCx
May 22, 2009 02:00 PM
nutlog13
Sep 17, 2008 07:13 AM
GSR1hits
Mar 16, 2008 05:42 AM
bboyoracle
Jul 3, 2006 10:37 AM
teewhy55
Jan 3, 2005 03:28 PM
