Using Aircraft remover...
When you guys use it, do you spray a shitload til most of the paint deteriorates? I'm spraying it and it gets bubbly, then when i tried sanding it with 240 grit, i still get some leftover paint...
i sprayed it on, waiting liek 4 minutes scraped it off and then sanded.
repeated like 4 times, i only did my spark plug cover tho, so idk what yoru doing.
good luck
good luck
Wait the time that it says on the can..that works the best. But yea your gonna have to go back again maybe twice to get it all off if you cant get it off with just sandpaper.
