A6/Z6 dizzy photo (searched)
Old May 12, 2005 | 12:25 PM
shbrown's Avatar
Default A6/Z6 dizzy photo (searched)
Does anyone have a photo handy of an A6 dizzy on a Z6 head? I have searched, and there are many descriptions of how to mount it up, but I would like to see a photo. If anyone has this set up, please help!
-Simon
Old May 12, 2005 | 12:40 PM
Brownjd's Avatar
Default Re: A6/Z6 dizzy photo (shbrown)
i can take one tonight. r u having trouble getting it to work. you can actually put it on there without cutting anything but won't be able to adjust for timing at all.
Old May 12, 2005 | 12:47 PM
shbrown's Avatar
Which bolt lines up? I can't get the top one in without a little shaving. If I get the top in, the other 2 need washers and a little shaving. But I am not clear if this will even be remotely close on timing. It looks closest with the top one in, but I am not sure. If I line up the front or back, then I will only have 2 of 3 anywhere close.
Old May 12, 2005 | 02:29 PM
Mach69's Avatar
Default Re: (shbrown)
I only have ONE arm of the distributor lined up with my Z6 head. Yes I did have to shave a lot from the top of the hole in the arm just for the bolt to go through it and bolt it to the head. I currently have 2 bolts holding my distributor to my head. One bolt on the top arm and the other outside of the arm closest to the firewall, pinching the arm to the head.
Old May 12, 2005 | 04:03 PM
mr. carpenter's Avatar
Default Re: (Mach69)
https://honda-tech.com/zerothread?id=913151
there you go. still adjustable.
Old May 12, 2005 | 04:36 PM
shbrown's Avatar
Thanks!! Guess my searching skills need some help. Great link.
kr3wkid420
Sep 23, 2015 07:01 PM
broke88rex
16
Oct 6, 2011 03:36 AM
Red_ED8
Dec 6, 2007 11:22 AM
AJxr
Dec 24, 2005 05:13 PM
d15b7racer
17
Jan 12, 2005 03:04 PM
