How to clean up head?
Old May 12, 2005 | 12:24 PM
shbrown's Avatar
Default How to clean up head?
I have my head off for a mini-me. I need to get the coolant out of the block and oil out of all the bolt holes before putting the head on. What is a good way to go about doing this?
Thanks!
-Simon
Old May 12, 2005 | 02:03 PM
ServiceAdvisor's Avatar
Go get a shop vac with a small attachment, I think Sears carries the attachment. Thats how I usually do it. But I fill the outside of the sleeves with coolant/water and the oil should rise to the top. - Darrell
Old May 12, 2005 | 02:06 PM
Joebroni's Avatar
Oven Cleaner is a good way to clean some heavy-duty **** from a motor. Just follow the directions.
Old May 12, 2005 | 02:39 PM
2fast4udude's Avatar
Default Re: (Joebroni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni &raquo;</TD></TR><TR><TD CLASS="quote">Oven Cleaner is a good way to clean some heavy-duty **** from a motor. Just follow the directions.</TD></TR></TABLE>
haha that sounds funny. "just follow the directions" yes, becuase oven cleaner has directs on how to clean a head
just joshin ya
Old May 12, 2005 | 03:21 PM
blackrex's Avatar
Default Re: (2fast4udude)
Uh...use a towel?
Old May 12, 2005 | 03:50 PM
shbrown's Avatar
Shop vac sound like the answer. But I don't have one (yet) It is hard to use a towel to get into the outside of the sleeves and into the bolt holes. Is there any way to crank the water pump to pull water out? I guess the oil wouldn't be good to get into the coolant system though....
Old May 12, 2005 | 05:47 PM
SixxT9's Avatar
Default Re: How to clean up head? (shbrown)
Clean up head? Not an issue if she swallows
In addition to the other suggestions, you might wanna try engine degreaser or spray on some lemon juice and let it sit before using the wet/dry vac. Basically anything that'll start to break it down to make the actual vacuuming process less time consuming.
vtechachey
Feb 1, 2008 10:13 AM
mafia
Feb 3, 2007 07:41 PM
ShawnR
Jan 20, 2006 12:24 PM
Serdar
Aug 24, 2005 10:56 PM
rjay8604
Jan 12, 2005 08:12 AM
