Starter not engaging new flywheel? Starter checks out ok.
Old May 12, 2005 | 11:59 AM
Greyout's Avatar
Default Starter not engaging new flywheel? Starter checks out ok.
A friend of mine is having difficulty with the new clutch/flywheel he installed in his '97 base.
the flywheel is bolted on right side up. The tranny and starter are secure. When the key is turned, the starter can be heard spinning, but the motor does not turn. The motor was turned slightly by hand, and this had no effect.
The starter was tested, and it functions normally.
I am at a loss as to what possibly could be wrong.
Old May 12, 2005 | 01:42 PM
xbn83's Avatar
Default Re: Starter not engaging new flywheel? Starter checks out ok. (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">A friend of mine is having difficulty with the new clutch/flywheel he installed in his '97 base.
I am at a loss as to what possibly could be wrong.</TD></TR></TABLE>
Do you hear anything beside the sound of the starter spinning? What kind of flywheel did he put on?
Old May 12, 2005 | 01:45 PM
Paul H22A4's Avatar
Default Re: Starter not engaging new flywheel? Starter checks out ok. (xbn83)
It's my car.
Only the starter spins, no other noises. It's a Fidanza 8.5 lb flywheel.
Old May 12, 2005 | 02:04 PM
xbn83's Avatar
Default Re: Starter not engaging new flywheel? Starter checks out ok. (Paul H22A4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul H22A4 &raquo;</TD></TR><TR><TD CLASS="quote">It's my car.
Only the starter spins, no other noises. It's a Fidanza 8.5 lb flywheel.</TD></TR></TABLE>
Do you know that when you installed the starter teeth matched up with the ring gears of the flywheel?
Old May 12, 2005 | 02:30 PM
Paul H22A4's Avatar
the teeth appear to not reach. the arm extends out and spin, but makes no contact with the flywheel.
Old May 12, 2005 | 06:41 PM
Honda Sport's Avatar
my friend's ring gear on the FW was spinning WITHOUT the FW. double check to see if that's happening to you. I believe he had a 8.5lbs fidanza too.
G60
Oct 13, 2020 12:58 PM
MikekiM
Jan 18, 2005 09:47 AM
g2homboi
Jul 2, 2004 11:27 AM
cstay
May 14, 2004 06:30 PM
92lsr
Jan 17, 2004 09:27 AM
