need to know what theis hoses are on a type sh lude
Old May 12, 2005 | 11:17 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default need to know what theis hoses are on a type sh lude
my bros sh what are theis hoses goin over the starter that go to the radiator we checking it and dont wanna
take them off not knowing what goes through it
and this is my car no hoses there but my old aftermarket rad had a place for the hoses
to go but no hoses whats up wit that?
Old May 12, 2005 | 11:44 AM
98TypeSH's Avatar
Default Re: need to know what theis hoses are on a type sh lude (raylude)
Those would be ATTS cooling lines. You can disconnect them TEMPORARILY, then reconnect and bleed the cooling system. Dont remove them unless you want to totally fry your atts unit.
Old May 12, 2005 | 12:07 PM
raylude's Avatar
Default Re: need to know what theis hoses are on a type sh lude (98TypeSH)
so what goes through it gear oil or antifreeze/coolant?
if its for atts why did my replacement radiator have the same thing on the radiator for the hoses?
Old May 12, 2005 | 12:45 PM
JP Page's Avatar
Maybe it the radiator is universal for SH and base ludes?
Old May 12, 2005 | 01:02 PM
Nextelbuddy's Avatar
Default Re: need to know what theis hoses are on a type sh lude (JP Page)
edit im a dumb *** posted in wrong thread sorry
Modified by Nextelbuddy at 2:31 PM 5/12/2005
Old May 12, 2005 | 01:46 PM
98TypeSH's Avatar
Default Re: need to know what theis hoses are on a type sh lude (Nextelbuddy)
I got all the part numbers for all the radiators.
SH
Denso: 19010-P0F-J53
Toyo: 19010-P0A-902
Base
Denso: 19010-P0F-J04
Toyo: 19010-P0F-J02
Its coolant/anti-freeze that run through those lines. they come out of the radiator, do you put oil in your radiator ?
Old May 12, 2005 | 02:03 PM
raylude's Avatar
i sell radiators at work and some come with motor oil coolers or tranny coolers inside the radiator so i didnt know witch one this was anyway we checked it, its cool but we found something else i guess when the intake was put on was this part needed or should i take it off?
Old May 12, 2005 | 02:19 PM
98TypeSH's Avatar
Follow that hose to the back of the intake manifold, pull it off, and cap the nipple with a vac cap. ( these can be purchased at pepboys, autozone etcc.) I dont think that it runs to a vac box but its been so long since if done an intake install, it might.
Old May 12, 2005 | 02:49 PM
raylude's Avatar
yeah did that im more woried about this thing with the electrical connection
thunderfck
Mar 9, 2013 09:48 AM
CuteAccord
Nov 24, 2009 11:24 PM
Ricearonie
Nov 19, 2007 06:39 AM
B18Redline
Dec 2, 2004 09:35 AM
White S2k
Nov 9, 2002 03:39 PM
