ls/vtec cams
Old May 12, 2005 | 06:10 AM
xDicktonesx's Avatar
Default ls/vtec cams
just got a b18a bottom end and im thinking of building a frank. however, i heard the valve to piston clearance is small enough that anything more than a mild cam is going to cause contact between the piston and valve. anyone know the largest cam that can be run with the b16a head/ b18a bottom end setup?
Old May 12, 2005 | 08:24 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: ls/vtec cams (CRXofPain)
Stock gsr cams are the largest i would go, Spend the extra money and get a set of p30, or p73-j00 pistons= higher compression and wider selection of cams that will make excellent power.
Old May 12, 2005 | 08:28 AM
Default Re: ls/vtec cams (PURPLETERROR)
higher compression would mean they are dome top which would mean less piston to valve clearance wouldnt it?
which head gasket should be used? just a stock b18a? whats the thinnest i could use with gsr cams and not have contact between the pistons and valves?
Old Jul 24, 2005 | 11:18 PM
JINX'D's Avatar
(thread hijack!!)
Sorry for the old thread bump, but this thread is the only thing that came up on my search..
my question: Can i keep my Civic TypeR cams when i do an LS/Vtec swap??
I still have my old cams (stock SiRII)
(thread hijack!!)
Old Jul 28, 2005 | 12:52 AM
JINX'D's Avatar
Default Re: ls/vtec cams (JINX'D)
Bump?
Old Jul 28, 2005 | 12:59 AM
Agent_STFU's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain &raquo;</TD></TR><TR><TD CLASS="quote">higher compression would mean they are dome top which would mean less piston to valve clearance wouldnt it?
The B20 pistons don't have valve reliefs like other OEM pistons. A high dome is fine, as long as the valve reliefs are there.
negusjuda
Apr 11, 2011 06:43 PM
0c00l
Jan 3, 2008 11:43 AM
sivikvtec
Aug 31, 2006 10:17 AM
civicgeek133
May 17, 2006 08:41 PM
ChaseIntegra
May 27, 2005 02:36 PM
