crome 1.1.5 question about IACV/itb's
Old May 12, 2005 | 05:01 AM
machine4321's Avatar
Default crome 1.1.5 question about IACV/itb's
does anyone know if the newest verion of itb tools disables the iacv
my car has been drivning like it has not iavc,its bucking really bad in traffic and ant maintain any speed with out the car jerking back and forth
i unpluged the iacv and it makes no difference and i dotn get a code at all...i used a friends bin from an older version and it throws a code even when it is conected(its ann obd 2 iacv and mabye thats why so yea just wondering if they disable the iac by default
Old May 12, 2005 | 05:46 AM
chameleon's Avatar
Default Re: crome 1.1.5 question about IACV/itb's (machine4321)
first of all do you even have itbs? 2nd version 1.1.6 is out. and 3rd iacv controls havent changed between the latest versions, iacv is not disabled by default that i know of.
Old May 12, 2005 | 06:17 AM
umm yes i have itbs....
ive downloaded the latest version so it must be 1.1.6 ..
the reason i ask is i dotn throw an iac code when its not hooked up ...but when i use older version ..liek the first version i get my iac code up ...
when i drive in traffic it feels like not having an iac ...it revs up and down very fast at 1500 rpm and when i try to keep a steady speed it jerks on me and throttle shuts off abruptly and comes back on ...then off then on ...very hard to drive ..in fact im sick of it lol so i took the cavaqueer to work today
yea i ahvent been able to find anything saying its been disabled but i cant even post on pgmfi right now for some reason posted dont go through
Old May 12, 2005 | 09:50 AM
RedZone's Avatar
Default Re: (machine4321)
It might be that the TPS voltage is off and it needs to be scaled in crome.....you should have someone that knows crome take a look at your bin file and adjust it......I would also recommend that you have the car tuned because the bin you are using is not for your engine and it could cause some damage if the car is not tuned properly
Old May 12, 2005 | 10:18 AM
both speedz and jdogg have had there go at it ..the car runs mint and is fast and judging by the plugs there burnign safely.....doesnt matter what bin how rich or how lean it is ...i cant shake this bucking ....liek i sad i would swear i had a manifold on the motor and my iacv wasnt workign
and i have scaled the tps correctly in crome as well ...theolder version knows the iacv isnt the right one a trows a code but the newest version has no codes....im gonna try a obd1 iac with the older version and see if it helps...
need ot get the vc leak fixed as well im sure its contributiing
thanks for the responces
Old May 12, 2005 | 10:34 AM
mtber's Avatar
Sounds like a vacuum leak to me.
Old May 12, 2005 | 10:41 AM
good cause i found one las night ..a big one in number 2 and 3 ......i hope thats all it is ..
Old May 12, 2005 | 11:17 AM
RedZone's Avatar
oh, cool....glad you found the problem
Old May 12, 2005 | 11:41 AM
lol i hope that is the problem...i found this last night and i wonder if it s been getting worse as the time goes....caus ewhen i first strated tunnign the car was very drivable but took tim e to get the a/f right....then as i got the a/f better the drivability got worse ..
seems liek the obvious start of a long road of double checking my timming belt and dizzy timming and the like
Old May 18, 2005 | 09:45 AM
well the vacc leak was not the problem how ever it runs twice as good now ..
but i was right about the iac problem ...the ecu was going nuts and no tthrowing a code..
went back the older version got a code and the car drove liek it was brand new agian
im soo happy i just hope that somone can figure out the problem with 1.6 so i can go back to it
Old May 18, 2005 | 10:30 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Send John Cui an email or make a thread on pgmfi.org. He can't fix a problem if he doesn't know its there.
Old May 18, 2005 | 10:55 AM
yea just finished sending him a pm and posted in the bug thread ...
i wonder if im the only one with this problem
Old May 20, 2005 | 04:38 AM
well it seems that 1.6 doesnt disable iacv but it doesnt realize that its not there and try's to function even when its no tthere
so i hooked up an obd1 iac ans it works fine...still hard on and off the throttle but other thne that at least i can drive with looking new
JDM_Certified
Jun 30, 2009 08:47 AM
1337 Si
Oct 2, 2008 01:59 PM
Bnjmn
Jan 3, 2004 04:50 PM
