civic si
Old May 11, 2005 | 11:59 PM
blanco's Avatar
Default civic si
ok i picked up a hatch from the police auction and the water pump seized breaking the timing belt. i replaced them both and for some reason the car bogs out at 4k rpms. i replaced the plugs wires cap rotor and the fuel filter. could this be a bad head? i even used a dizzy from a perfectly running car and i still got the same problem. what could this be? i am confused!!!!!
Old May 12, 2005 | 12:08 AM
CRXDrew's Avatar
broken timing belt is bad news... bent valves maybe.
Old May 12, 2005 | 12:23 AM
blanco's Avatar
Default Re: (CRXDrew)
could valves really be bent? it sounds fine!
Old May 12, 2005 | 04:29 AM
txq45's Avatar
Try replacing the temp sensor.. The civic will go into fail safe mode and will not go past a certain rpm if it is bad....
Marcosdlt
Jun 23, 2013 08:55 PM
joshd_bh
17
Jun 4, 2012 01:57 AM
1993dagsr
Jul 3, 2010 09:37 AM
1993dagsr
Jul 2, 2010 10:28 AM
Wayne_Curr
Apr 3, 2006 10:57 PM
