Clunking feeling under the floorboards (axle?) when i am turning left hard, doesnt happen when i tur
there is some sort of clunking, like an axle is hitting or popping in and out when i make a hard left, doesnt do anything when i make a hard right. The driver side has always had problems even with new axles im not sure what it could be. I replaced the axle 2 times after clicking cv joints. Now i have a 5 lug conversion done by a shop with prelude 97+ axles and i am getting this problem.
At first i thought it was my tires rubbing (felt similar to it) and i had 215/45/16's. Now i went to 205/45/16 and they still do it! This rim is about 1" wider (jdm type r 98+ spec rims) but still shouldnt rub like this. Any ideas?
Also one more thing, the inner fender liner on the passenger side is cut off, but the driver side is in tact.... could it be the fender liner?
have the same problem, was going to do the CV joint but if you said you replaced it I am going to hold off.
Sounds like it might be the steering rack?
I get these when I go right lol
I always thought it was the lower front tie-bar I put on there...
check the bushings, maybe tire hitting something...it's a clunking and pretty sudden.
mingbling96
Mar 13, 2005 08:14 AM
