K24A4 head swap
Has anyone successfully put a K20A2 head on a K24A4 block? I've heard from several people now that the pistons hit the valves, despite what SCC magazine and other sources say.
Archidictus is in the process of tearing everything back apart now after figuring out the problem. Has anyone else run into this? Could it be that the K24 pistons are larger diameter than the K20's?
I've only found one piston manufacturer so far that's addressing the issue, but I've never heard of the company before..
$479 a set with rings
http://www.cppistons.com/sCompactNEW.htm
SC7145 K24 w/K20A/A2/A3 Head 3.425" / 87.0mm SizeSTD CH1.181 CR11.5:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr »</TD></TR><TR><TD CLASS="quote">Archidictus is in the process of tearing everything back apart now after figuring out the problem. Has anyone else run into this? Could it be that the K24 pistons are larger diameter than the K20's?</TD></TR></TABLE>
I have first hand testimony from Nikos and Brian G at HASport that this is a bad idea. I'm tearing her down now and figuring out wtf I'm going to do with the wrong K24 and a K20A2 head and ECU.
Sigh.
Sigh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaluver »</TD></TR><TR><TD CLASS="quote">i would change the pistons, and just build the block and put the head on it...</TD></TR></TABLE>
Sounds like a good plan, we'll have to see how Archi makes out.
right now I have a k24a4 with a k20a2 head on the motor. I clayed the motor and and then I scaled it, the motor had a little more then .040 ptv clearance.
Modified by 96turboteg at 12:01 PM 5/20/2005
MatHadder
12
Mar 4, 2007 02:59 PM
DB2#308
May 17, 2004 11:54 PM
