Back up / Reverse lights for 00 civic hatch.
Old May 11, 2005 | 02:42 PM
tEhNgUyeN's Avatar
Default Back up / Reverse lights for 00 civic hatch.
Well im having trouble with my tail lights, everything seems to be working besides my back up lights.. when i bought the hatch it had ricey apc crap lights on them so i swapped the oem ones back on and the guy said i needed to buy new bulbs.. so i did and nothing happened. Turn signals brakes and lights work but reverse dont.. can someone help me out?
Old May 12, 2005 | 11:16 AM
tEhNgUyeN's Avatar
Default Re: Back up / Reverse lights for 00 civic hatch. (tEhNgUyeN)
Could it be a fuse?
Old May 12, 2005 | 11:24 AM
civiccpedx's Avatar
you could start by checking the fuses, also check the connections, make sure none of the wires are loose or anything
Old May 12, 2005 | 12:12 PM
BlueIntegraBoy's Avatar
Check fuses
Old May 13, 2005 | 07:15 PM
tEhNgUyeN's Avatar
Default Re: Back up / Reverse lights for 00 civic hatch. (BlueIntegraBoy)
I checked the fuses the fuse for the reverse lights dont click into the socket, it's easily put in and removed.. i changed the fuses/bulbs and the lights still do not work
Old May 13, 2005 | 07:18 PM
civic_fan's Avatar
Im assuming that you have a 5 spd tranny.....theres a sensor on your tranny that is for your reverse lights...check that out....I bet its your problem.
Old May 13, 2005 | 07:29 PM
GSlowR's Avatar
Default Re: Back up / Reverse lights for 00 civic hatch. (civic_fan)
i've got this exact problem on my 95 civic /w gsr motor.. after we put in my short shifter the reverse lights don't work.. doesn't make any sense any ideas??
Old May 14, 2005 | 07:49 AM
tEhNgUyeN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_fan &raquo;</TD></TR><TR><TD CLASS="quote">Im assuming that you have a 5 spd tranny.....theres a sensor on your tranny that is for your reverse lights...check that out....I bet its your problem.</TD></TR></TABLE>
yes, i have a 5 speed but before i bought the car the guy had apc crappy lights on it and i installed the OEM ones back and thats when they reverse lights started to not work, the guy said something about i need to replaced the bulbs and i did.. i'll check out the sensor.
Old May 14, 2005 | 07:57 AM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
If you didn't trash the apc lights see if they work now, maybe it's a problem with the oem lights.
Old May 14, 2005 | 08:05 AM
T4eg's Avatar
depending on the state..here in VA if u cut the "plug" off for reverse lights u dont need them for inspection
Old May 14, 2005 | 09:07 AM
tEhNgUyeN's Avatar
Default Re: Back up / Reverse lights for 00 civic hatch. (T4eg)
in fl we dont even have inspection.. its just i'd rather have the backup lights work then not work..
Old May 14, 2005 | 05:35 PM
GSlowR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">depending on the state..here in VA if u cut the "plug" off for reverse lights u dont need them for inspection
I never knew that.. i got inspection this month.. i have no clue how to fix this problem.. what plug?? the ones to the backup lights? where the bulbs plug in..
sweux
Aug 5, 2017 06:02 AM
HiGhGuY
Jun 27, 2014 11:54 PM
chickenandpickles
Apr 25, 2005 05:20 AM
NiceDc2r
May 13, 2004 09:42 PM
hatch808
Sep 14, 2003 05:22 PM
