CTR vs ITR Pistons
Old May 11, 2005 | 01:59 PM
ALMXDUPINTEGRA's Avatar
Default CTR vs ITR Pistons
What are the differences and what would be a better choice? Why?
Old May 11, 2005 | 04:07 PM
IggyBcool's Avatar
ctr has more compression than itr. the ctr will put a gsr to about 12:1 where as a itr will put it to about 10:6 and the jdm itr pistons will put u to 11:1
which one would be a better choice? well it depends on what ur going to do with ur car..
Old May 11, 2005 | 10:54 PM
mtber's Avatar
Default Re: CTR vs ITR Pistons (ALMXDUPINTEGRA)
Run the JDM itrs or JDM p30s
CTRS will work fine, but such a high c/r without proper tuning can cause some detonation issues.
Old May 12, 2005 | 03:25 AM
ar2d2's Avatar
I would agree with 99whitejizzer,the question is on what you have planned for your motor.If you plan to go N/A then its a toss up between the two.Also if you decide to run the CTR's,have your motor tuned.Just like mtber said you don't want any detonation issues.Just do more searching and ask more questions if you can't find what you're looking for,also its going to come down to personal preference.Thats my $0.02 for the day lol.
Modified by ar2d2 at 4:50 AM 5/12/2005
Old May 12, 2005 | 06:44 PM
I am just looking to change out the stock LS pistons. I know the LS pistons wont let me rev past 7K. I have a LS VTEC set up. B16 head with B18B block. What about for speed?
Old May 14, 2005 | 09:55 AM
ar2d2's Avatar
Default Re: (ALMXDUPINTEGRA)
Either pistons will work but its just going to come down to preferance on which pistons you want to use.
Old May 14, 2005 | 02:08 PM
Would the CTR's give me better compression numbers?
Old May 14, 2005 | 02:47 PM
IggyBcool's Avatar
Default Re: (99whitejizzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99whitejizzer &raquo;</TD></TR><TR><TD CLASS="quote">ctr has more compression than itr. the ctr will put a gsr to about 12:1 where as a itr will put it to about 10:6 and the jdm itr pistons will put u to 11:1
which one would be a better choice? well it depends on what ur going to do with ur car.. </TD></TR></TABLE>
already been covered a long *** time ago
Old May 14, 2005 | 03:57 PM
apok's Avatar
Don't put anything in your motor until you know what each part of the motor does.
Old May 14, 2005 | 04:08 PM
IggyBcool's Avatar
Default Re: (apok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apok &raquo;</TD></TR><TR><TD CLASS="quote">Don't put anything in your motor until you know what each part of the motor does.</TD></TR></TABLE>
that wuz mighty random...
Old May 14, 2005 | 05:57 PM
OBD1Kenobe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">I know the LS pistons wont let me rev past 7K.</TD></TR></TABLE>
How high you can rev is not determined by your pistons. It's a combination of crank dynamics and valvetrain.
Old May 14, 2005 | 09:30 PM
Gqracer's Avatar
Default Re: (OBD1Kenobe)
go with the ctr. .look at the other piston weisco, ross , arias. dome and high comp like the ctr anyways.
Old May 15, 2005 | 01:43 AM
yrethguad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBD1Kenobe &raquo;</TD></TR><TR><TD CLASS="quote">How high you can rev is not determined by your pistons. It's a combination of crank dynamics and valvetrain.</TD></TR></TABLE>
And rod/bolt strength.
Old May 15, 2005 | 05:10 AM
Will stock LS Rod and bolts w/CTR pistons hold up past 8K RPM.
Old May 15, 2005 | 07:03 AM
yrethguad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">Will stock LS Rod and bolts w/CTR pistons hold up past 8K RPM.</TD></TR></TABLE>
There was a magazine article on this, and I believe what failed was the bolts. They recommended ARP bolts.
Don't take my word for it though, just trying to point you in the right direction. I believe it was Honda Tuning.
For what it's worth, when I do my build..... someday..... I'm going to use aftermarket rods, probably Carrillo.
JDM Lyfestyle
15
Jun 21, 2009 04:59 PM
jdmfranky
May 30, 2005 04:45 PM
Type RS
Feb 14, 2004 05:22 AM
CircuitFG
Jul 5, 2003 09:01 AM
Big Teggie
Jan 25, 2002 12:48 AM
