Idle adjust screw/ Base idle adjuster screw
ive heard it called both things. Anyways, i adjusted it because my integra wasnt idling high enough. I realize now that it may have been a big mistake. After i adjusted it i noticed that the pedal seems to stick a little bit before it starts to give the car gas when being depressed. When shifting if you dont rev match it kind of makes the car jerk because of it.
So my question is...
Should that screw always be left alone? Did i make a big mistake and is the only way to get it back to the correct position trial and error?
Thanks in advance,
Ben
Modified by bengeeee at 10:49 PM 5/11/2005
Thanks in advance,
Ben
