Idle drops down low when at a stop
Old May 11, 2005 | 01:37 PM
ghost_ryder35's Avatar
Default Idle drops down low when at a stop
When I am on my brakes in my CRX and at a stop the idle drops from 1000 to 500 and sometimes even lower. When I get off the brakes it idles back at normal. Just replaced master cylinder and all calipers and rotors... any ideas? Is there an air bubble in one of my lines? Any help would be great. Thanks!
Old May 11, 2005 | 02:34 PM
Default Re: Idle drops down low when at a stop (ghost_ryder35)
bump
Old May 11, 2005 | 02:47 PM
gutterslide's Avatar
sounds like the MAP sensor, or a vacuum leak. does it idle fine when in park? does it drop really low when you turn on AC or heat? or put it in gear?
Old May 11, 2005 | 02:56 PM
Default Re: Idle drops down low when at a stop (gutterslide)
Idles fine when I am not touching the brake pedal. Does not drop down when ac / or heat is turned on. So no one thinks it has anything to do with my brakes. Maybe just the map sensor.
Old May 12, 2005 | 04:31 AM
txq45's Avatar
Sounds exactly like the brake booster line..
Old May 12, 2005 | 10:46 AM
Default Re: (rexwreck)
Where is the brake booster line located? Pictures would greatly help!
Old May 12, 2005 | 10:55 AM
Default Re: (ghost_ryder35)
Just to add one more thing. If you pump the brake pedal fast when the idle drops the idle will raise to normal idling.
Old May 12, 2005 | 11:27 AM
vegaskurt's Avatar
Mine is doing the same thing. Only when the car is completely stopped...... Take my foot of the break and its fine.
Anyone have a pic of the booster line you are talking about?
Old May 12, 2005 | 05:20 PM
thanks a lot, I'm driving my all-trac right now so when I get home I will check it out. But if i remember i did see a crack in it when i swapped the motor in awhile ago. Thanks once again this problem was so anoying
Modified by ghost_ryder35 at 6:39 PM 5/12/2005
Old May 12, 2005 | 05:54 PM
blue skunk2's Avatar
This is a possibility also, it could be a clogged IAC Valve with excess carbon clogging the screen preventing it from idling good.
pmrider
Jul 9, 2009 09:45 AM
stripes777
Apr 27, 2008 02:34 PM
slim9300
Jul 14, 2004 10:14 AM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
