Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
15x 6.5 42 offset vs 15x7 40 offset wheels
Old May 11, 2005 | 01:16 PM
CRX Toad's Avatar
Default 15x 6.5 42 offset vs 15x7 40 offset wheels
On 88-91 CRX (H4/H5? HC Track Car), rim weight is close to the same
1. Any benefit of one over the other with a 205/50/15? (handling, is 1/2" going to matter, turn in, sidewall flex, point at where tire breaks loose (progressive or immediate)...)
2. Would there be rubbing issues? (inside or fenders)
3. Any experience or genuine knowledge that would be useful...(tire selection, rubbing issues, suspension, etc)
Old May 11, 2005 | 01:33 PM
paok818's Avatar
1. 205/50/15 on a 7" wide rim would give you more contact patch compared to 6.5" wide rims. which will in turn give you more grip cause more of you're tire is touching the floor.
2. rubbing would depend on how much you are lowered by.
3. i don't have a hatch so can't say about suspension stuff. but tires would depend on your budget i guess.
Old May 11, 2005 | 01:34 PM
jisu009's Avatar
Default Re: 15x 6.5 42 offset vs 15x7 40 offset wheels (CRX Toad)
I run a 15x7 40mm offset with 205/50/15 Azenis on my 1990 hatch.
You will need to roll the rear fenders otherwise they will rub bigtime. With the rears rolled there are no rubbing issues.
Old May 12, 2005 | 04:49 AM
CRX Toad's Avatar
Default Re: 15x 6.5 42 offset vs 15x7 40 offset wheels (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">I run a 15x7 40mm offset with 205/50/15 Azenis on my 1990 hatch.
Good to know. I figured that the fenders would probably need to be rolled...greatly appreciated
Old May 12, 2005 | 05:03 AM
typer_801's Avatar
I believe in the autocross world, it's been verified that going from a 6.5 to a 7.0 inch width wheel on a 205/50/15 is worth around 1/2 second on ~40 second course. So it's a difference you'll feel and will be reflected in your times.
Old May 12, 2005 | 04:02 PM
CRX Toad's Avatar
Default Re: 15x 6.5 42 offset vs 15x7 40 offset wheels (typer_801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">I believe in the autocross world, it's been verified that going from a 6.5 to a 7.0 inch width wheel on a 205/50/15 is worth around 1/2 second on ~40 second course. So it's a difference you'll feel and will be reflected in your times.</TD></TR></TABLE>
Interesting.....so the 1/2 is actually valuable.
Old May 12, 2005 | 04:11 PM
TeamSlowdotOrg's Avatar
Rim width is a specified quantity for a lot of racing classes (like ITA, for instance) because it limits performance (to a point). Durr?
Old May 13, 2005 | 12:30 AM
funz0rzies's Avatar
1/2" on all 4 wheels adds up to 2" total...
redGSRguy
Oct 19, 2006 12:31 PM
Rob.
Mar 20, 2006 12:53 AM
stickyfingers
Mar 10, 2004 07:03 PM
magic hat #9
Mar 8, 2003 04:33 PM
Mike D
Jul 31, 2002 09:52 AM
