gears grinding?
Old May 11, 2005 | 01:13 PM
GuCCi_GSR's Avatar
Default gears grinding?
sometimes my gears grind. i dont think its my tranny (synchros) because i dont drive the car hard. could it be my tranny oil level is low? or is my clutch going?
Old May 11, 2005 | 02:53 PM
Rpizzle's Avatar
Default Re: gears grinding? (GuCCi_GSR)
does it grind going into third?? if so it is your syncros wearing out, it's common in Integras, I say replace your existing fluid with GM Synchromesh fluid, should eliminate most of the problem. hope this is good enough info
Old May 11, 2005 | 03:09 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: gears grinding? (Rpizzle)
Is it hard to get into gear at all, or just grinding?
Mine started getting really sticky then started to grind a little.
when I took my clutch out, one of the springs was coming out.
Old May 13, 2005 | 01:19 PM
GuCCi_GSR's Avatar
Default Re: gears grinding? (FlatBlackTeg)
its sometimes hard to get into gears. i dont want to force it, but sometimes it sucks it in and it grinds. what should i do? i dont want to damage my tranny.
Old May 13, 2005 | 01:41 PM
.water's Avatar
do that things that u can do quick. tranny fluid change, clutch fluid.
Old May 13, 2005 | 06:53 PM
VINtegra90's Avatar
i said something in here that might actually help u
https://honda-tech.com/zerothread?id=1244698
Old May 13, 2005 | 09:41 PM
iloveboys's Avatar
Default Re: gears grinding? (VINtegra90)
change your tranny fluid and see if that helps. GM syncromesh is butter smooth but the honda mtl is good also. i never use regular oil because the shifts are way too notchy for me.
red5FWD
Jan 27, 2008 07:43 PM
bomber19
Oct 3, 2007 05:57 PM
JDM-Vic
Apr 6, 2004 01:48 PM
vtechatch
Feb 27, 2003 02:33 PM
makaveli284
Oct 2, 2002 09:53 PM
