planning to build y8 that can handle 75 wet shot.
Old May 11, 2005 | 12:11 PM
CIVIC96DXcp's Avatar
Default planning to build y8 that can handle 75 wet shot.
any suggestions?
what's the best combo. planning to use stock y8 head, most likely ported and polished. right now, i;m focusing on the bottom end.
please give me your input, on what would you do.
my budget is $1000.
thanks
Old May 11, 2005 | 12:35 PM
Luserkid's Avatar
Default Re: planning to build y8 that can handle 75 wet shot. (CIVIC96DXcp)
From my understanding Nitrous is more on air fuel mixture over a build, kind of like with All motor unlike boost which is infact pressure onto pistons, rods, valves, etc. so a build is a must for big power. Its always a good idea to build but its better to get a good managment. With good tuning you could use the 75 shot on a completely stock motor. If you get into the 100s then i suggest building.
Old May 11, 2005 | 12:49 PM
clutch878's Avatar
Default Re: planning to build y8 that can handle 75 wet shot. (Luserkid)
dont worry about the bottom end with only a 75 shot. no2 is hard as **** on the rings with that 1000 get pistons and rods and a good set of rings.
Old May 11, 2005 | 04:12 PM
what brand of pistons and rods would you recommend?
Old May 11, 2005 | 04:43 PM
Vtecme92's Avatar
Default Re: (CIVIC96DXcp)
I had a 92 ex and I had 85 dry shots of nos and I ran the track and the streets without any problems..I had a block guard, and changed my spark plug regularly and I was fine, but if you have a budget of $1000 you want to spend I would spend it on a plurge, pistons, and a good block gaurd!
Old May 11, 2005 | 04:58 PM
what's a block guard
Old May 11, 2005 | 10:32 PM
clutch878's Avatar
a block gaurd is a pice of metel that wraps around the sleeves and keeps them from moving. as far as pistons and rods go i would go with crower rods and aries or cp pistons. o.e.m. bearing and retard your timing 3 degrees. i would not worry about a plurge kit its a waste of money its just to show how rice you can be and its a waste of n02
Old May 11, 2005 | 10:34 PM
Default Re: planning to build y8 that can handle 75 wet shot. (clutch878)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutch878 &raquo;</TD></TR><TR><TD CLASS="quote">a block gaurd is a pice of metel that wraps around the sleeves and keeps them from moving. as far as pistons and rods go i would go with crower rods and aries or cp pistons. o.e.m. bearing and retard your timing 3 degrees.</TD></TR></TABLE>
i was thinking about using eagle rods. do i need to forged my internals?
Old May 12, 2005 | 07:09 AM
clutch878's Avatar
i would it will give you just that much more you can handle. i have had bad luck with eagle rods stretching.
Old May 18, 2005 | 05:57 AM
thanks man. any ideas where i can get the pistons and rods for a good price?
Old May 18, 2005 | 06:46 AM
menkio's Avatar
there's plenty of stores that sell rods and pistons, just go and look, eagle + weisco, whatever.. and compare price, bigger price bad, lower price good.. you get this. For a 75 shot and going with a stronger bottom end you kinda throw yourself in a grey area.. with rods and pistons you CAN run more than a 75 shot, but like with anything a balance must be achieved. Get your rods and pistons, get a new head gasket(which you have to replace anytime you lift your head off the block) and new studs, same thing as the hg.
Last, you need the tune the engine with that extra power your throwing at, not just the "brain" or solenoid, whatever system you go with.. make sure this is done my a competent tunner with experience.
anymore questions during your build msg me up, i don't mind helping at all. good luck
btw, http://www.lightningmotorsports.com
rods and pistons can be bought threw them, also you will need new bearings(acl) and the people at lightning are great.
Old May 18, 2005 | 07:08 AM
v4lu3s's Avatar
RTFM
my build up for a 75 shot of nitrous on that engine would incluide a compression test. if that comes out good id get some colder sparkplugs and spray away.
j0keefe21
31
Nov 13, 2009 11:49 PM
dohdoh420
Jun 7, 2006 08:20 PM
spencerv
Aug 28, 2002 08:39 PM
sleepercivic143
Mar 19, 2002 06:57 AM
BSpec24
Jan 16, 2002 01:39 AM
