Mixing oil viscosity's..?
I found what seems to be a small oil leak today. It may be a seal since it's coming from the front around the radiator area.
My question is: I had an oil change and decided to use Valvoline Max Life 5W-30. I had a brain freeze and bought 10W-30 and realized after I got home it was the wrong one. The oil leak may be fixed tomorrow but in the mean time, will mixing the viscosity's create any issues?
I live in Florida btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RallyRedGT-V6 »</TD></TR><TR><TD CLASS="quote">go back, return the oil and buy the right stuff...
****, not a hard solution</TD></TR></TABLE>
Damn man, take that ******* dick out of your mouth.
You didn't even answer the question. You did however, give out an advice in a rude manner.
Back on topic.
Mixing 10w30 and 5w30 will have no negative side effects on your engine.
They are pretty much the same weight.
Back on topic.
True, you will be fine. I run 10w30 M1 for 8k, it thicken to 10w40 as analysis said, then I add a quart of 0w20 and it mix back into 10w30, good to go for another 4k.
rota power
Aug 13, 2006 11:44 AM
