Ignition Output signal?
after about 4 months of having the teggy sitting i finally get around to start it and take out all the winter kinks. now i was getting a **** load of codes and i began fixing all the problems. now im stuck with Ignition output signal. does this mean that the dizzy is bad or that there is a problem with the crank or cam position sensor? thanks in advanced
check that the dizzy is getting power, then check the wiring at the ecu.
if all is fine, change the dizzy. if it still throws codes, put the old dizzy back on, change the ecu, test that.
check your grounds, make sure they're clean.
Ryan.
Apr 29, 2008 11:48 AM
Jet Black
May 13, 2004 08:17 AM
