Heat range 7 spark plugs for NA, yay or nay?
Is that a NGK part #? what is the heat range and is it good for NA setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s »</TD></TR><TR><TD CLASS="quote">gonna give you a plug number, no questions asked. R5671A-8's, no further questions.
Yupp, thats a NGK #, depending on how much advanced timing and compression ratio your gonna run depends on your heat rate, if your gonna run an All Motor LS, then go with a 7, but anything else like a built B16 GSR or Type R I would recommend 8's, use the R56718-8
generally speaking, you want to run the hottest plug that you can without signs of detonation. NGK heat range #7 is the most common plug for naturally aspirated setups. Of course different setup's will require either a step colder or hotter depending on various conditions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320JDMGSR »</TD></TR><TR><TD CLASS="quote">generally speaking, you want to run the hottest plug that you can without signs of detonation. NGK heat range #7 is the most common plug for naturally aspirated setups. Of course different setup's will require either a step colder or hotter depending on various conditions.
Not to thread jack... but how are those RM plugs working out? I see you're a RM dealer.
</TD></TR></TABLE>Not to thread jack... but how are those RM plugs working out? I see you're a RM dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
Not to thread jack... but how are those RM plugs working out? I see you're a RM dealer.</TD></TR></TABLE>
I just got a set of these plugs with my cams and will be dynoing them tomorrow back to back against some NGK's... stay tuned.
Whats so special about the R5671A-8's? According to NGK they have a resistor in them hence the "R".
I use NGK BKR7E on my Allmotor B18b. I used them too on my old nitrous motor.
</TD></TR></TABLE>Whats so special about the R5671A-8's? According to NGK they have a resistor in them hence the "R".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 »</TD></TR><TR><TD CLASS="quote">well they say its a copper race plug ...racing does mena fast right
No but copper is a good conductor!
</TD></TR></TABLE>No but copper is a good conductor!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">
I use NGK BKR7E on my Allmotor B18b. I used them too on my old nitrous motor.</TD></TR></TABLE>
I havent done the research but if you ask most of the all motor guys on H-T they will probably tell you that plug, I think DTR runs this plug, I know a bunch of other tuners recommend this plug also. I know people have posted up on that plug before, give it a search if your interested more.
Most places stock them, they are only like $1.70 somethin a plug, your not gonna pay more than $10 for a set, I know where I buy them from they usually have them (Napa Auto Parts) if they dont it only takes like 2 days to get them, check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c17r15 »</TD></TR><TR><TD CLASS="quote">I have the ngk v-power temp 8. Spoon uses them on their race cars.
I'm running the same plugs in my high comp LSVTEC, NGK stock number 4554. Didn't notice a difference going from the BKR7E-11s though.
</TD></TR></TABLE>I'm running the same plugs in my high comp LSVTEC, NGK stock number 4554. Didn't notice a difference going from the BKR7E-11s though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianSi91 »</TD></TR><TR><TD CLASS="quote">i have a ls vtec, ctr pistons , stage 3 cams
are 8's good for me?</TD></TR></TABLE>
I run 7's in my crx . I broke in a set of 7s' and then a set of 8's on the dyno and made 8 pulls with each and the power didnt change enough to run anyone over the next..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish »</TD></TR><TR><TD CLASS="quote">running 7's in my motor too</TD></TR></TABLE>
Quitripin
16
Aug 18, 2004 09:20 PM
