EG hatchback Si and EG coupe share the same hood?????
Old May 11, 2005 | 07:54 AM
CIVIC96DXcp's Avatar
Default EG hatchback Si and EG coupe share the same hood?????
my GF just got into a small accident. unfortunately, her hood is bent. she has a 95 EX, which i assume a EG. so, i bought a stock hood which came off from 92 Si. i installed it, and it turned out that the Si hood is a little bit too long.
my question is, does EX coupe and Si hatchback share the same size hood? it is possible that my GF has bent the front end a little bit.
thanks
Old May 11, 2005 | 07:56 AM
Soccerking3000's Avatar
Default Re: EG hatchback Si and EG coupe share the same hood????? (CIVIC96DXcp)
they are the exact same hood, so i am guessing the rad. support is bent in...
Old May 11, 2005 | 07:59 AM
Default Re: EG hatchback Si and EG coupe share the same hood????? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">they are the exact same hood, so i am guessing the rad. support is bent in...</TD></TR></TABLE>
right. the rad is tilted a little. is there anyway to fix this, to make it straight again?
thanks
Old May 11, 2005 | 08:06 AM
snatch's Avatar
Get a new radiator support.
Old May 11, 2005 | 08:07 AM
Default Re: EG hatchback Si and EG coupe share the same hood????? (******)
get a hammer and go at it? if you cant fix it like that then get a new radiator support, it cant hurt to try ya know?
Old May 11, 2005 | 08:08 AM
Mark27's Avatar
cut it out and weld on a new radiator support
Old May 11, 2005 | 08:09 AM
Luserkid's Avatar
You could try to pull it but doubt it would be perfect. A new rad. support would be best.
If your really low on budget i know someone who was in a small fender bender and he didnt have enough money for rad. support to be put on so instead he pushed the hood lock out alot with washers and a long bolt then planted it there. And also to be on the safe side he added hood pins (his hood was CF though). So thats something you might be able to do.
Old May 11, 2005 | 10:11 AM
how much is a radiator support?
Old May 11, 2005 | 10:35 AM
2000Ek's Avatar
Default Re: (CIVIC96DXcp)
You can check here for pricing here for a OEM Honda, but you can find a better price from a wrecking yard or aftermarket manufacturer.
http://www.hondaautomotivepart...cgry5=
I just picked up one from a wrecking yard for about $130. It was OEM Honda and had a lot of little extas (engine mount, wiring, hood latch, etc..)
Good luck.
Old May 11, 2005 | 10:43 AM
North_Texas's Avatar
Junkyard..
Old May 11, 2005 | 12:09 PM
junk yard it is then. thanks guys
Old May 11, 2005 | 12:12 PM
JDM SLICK's Avatar
same hood...same difference...
Old May 11, 2005 | 01:32 PM
t0ekn3e's Avatar
same hood
Old May 11, 2005 | 01:41 PM
Flyingchopstick's Avatar
i believe the whole front cap is the same.
EG_Savage 413
Feb 6, 2019 08:05 PM
AntHonda
Dec 20, 2010 11:48 PM
hondaon18's
Jul 28, 2007 10:14 AM
