Need info on D15B Swab with Turbo
I'm going to get the D15B from HMO but i need some information on a turbo kit for that engine. This engine is going in my Civic coupe i just bought for 1800 bucks. Engine has 189 thou on it and im going to toss it before i do anything. Where is a good place to get a completly turbo kit (Turbo, Intercooler, blow off valve...etc.) And what size turbo should i get without running into any problems.
check out http://www.homemadeturbo.com
probably a t25 for that motor would be great
and always remember:
go for the d15b... forget getting the whole thing as a kit... you'd be better off with a custom setup. Most kits out there have a bad fuel management system included, if you go custom chances are you'll end up spending less compare to how much you'll fork in for a kit, http://www.pgmfi.org do your research first.
go to http://www.homemadeturbo.com for the turbo info and i also agree on the t-25
Thanks ill look into it. Going to post pictures soon of the car not looking to bad right now
Just installed Projectors and SI tailights. Also just tinted out the windows the other day.
hi as u are a trial member so i cant pm u but im selling a partial turbo kit for ur motor check it out sorry to thread jack
https://honda-tech.com/zerothread?id=1241753
xkrntamax
Jan 12, 2008 02:05 PM
