Car died...need help
Old May 11, 2005 | 05:48 AM
Drive01's Avatar
Default Car died...need help
Coming home from work, one block away, I downshift and when I get back on the gas, there was nothing there. The car won't start anymore. I had to push her home. I didn't hear any crunching noise or anything, so I don't think its anything internal.
My first hunch was the timing belt slipped a couple notches. I checked that = ok.
I haven't checked for spark yet, cause I was by myself.
If it doesn't have spark, should I change the coil, or the ignitor, or both?
or just change the whole dang dissy? Or can I get away w/ buying MSD external coil?
Thanks for you help guys.
Old May 11, 2005 | 05:55 AM
Misfit's Avatar
Default Re: Car died...need help (Drive01)
It may be just the coil.. just stick with OEM on this one. how many miles are on the car?
this same thing happened to me on Tax day on the civic.
Old May 11, 2005 | 10:27 AM
200cs's Avatar
I had a similar problem with my ITR. It was giving a CEL but would still run. I replaced the weak OEM coil with a Jacob's coil and exciter box and an MSD cap rotor and wires. All of this was done before it was boosted and it made a noticable increase in performance as soon as I did it. Hope this helps.
Old May 11, 2005 | 10:45 AM
typer_801's Avatar
Default Re: Car died...need help (200cs)
I lost my rotor screw and it trashed my distributor. Car barely ran. I'd check to make sure it's not something obvious like that.
Old May 11, 2005 | 10:49 AM
blkitr's Avatar
my car did the same thing when one of my grounding cables came loose. confused me for days until i went digging around the ending bay and saw a lonely loose wire..
Old May 11, 2005 | 11:30 AM
Stealthycivicsi's Avatar
Default Re: (blkitr)
I had a similar problem, it turned out to be the coil. Best of luck to ya.
Old May 11, 2005 | 11:57 AM
Batoutahell's Avatar
Honda coils suck, they overheat and burn out. I now use Distributor King dizzy's on both my cars, much cheaper than oem and better quality. Plus the itrca.com discount.
Old May 11, 2005 | 12:12 PM
eMpAtHy's Avatar
Default Re: Car died...need help (Batoutahell)
msd blaster coil for me and msd sport compact
Old May 11, 2005 | 01:15 PM
Cone's Avatar
Default Re: Car died...need help (eMpAtHy)
check grounds. Has the car been acting funny before this? does it crank over? stumble? I assume you have power. One easy way thing to check for off the bat is when you turn the key forward listen for the 2 second fuel pump prime from the backseat.
Old May 12, 2005 | 06:33 AM
Drive01's Avatar
Thanks for all your help guys!!
My car ran fine before this, it was an all of a sudden thing..
And All my ground wires are good.
I'm pretty sure it's the coil.
I was contemplating on getting msd external coil, but there were other posts saying it causes other problems, while others say it kicks ars... hmmm weird.
I think I'll have to go w/ distributor king!!
thanks again!
95blackEG
Dec 24, 2008 07:59 PM
95blackEG
Dec 23, 2008 10:37 PM
silence238554
Sep 26, 2007 06:17 PM
R6INIT
19
Jul 24, 2006 07:40 PM
Crimson_Tide
Apr 9, 2005 12:21 PM
