Need help trouble shooting, (speedometer won't work)
Old May 11, 2005 | 05:37 AM
singlecammajamma's Avatar
Default Need help trouble shooting, (speedometer won't work)
Hi guys,
I have a problem with my 95 honda civic ex. The car is basically stock and runs good. The only problem is that my speedometer does'nt work properly, somtimes it would cut on as i am driving and then off. It would bounce from 0 to whatever speed i am going, then go back to 0. Does anybody now what i should start checking how I can trouble shoot this?
Anyhelp is much appreciated. Thanks
Old May 11, 2005 | 06:36 AM
RacerXI's Avatar
Default Re: Need help trouble shooting, (singlecammajamma)
It sounds like a bad VSS or a bad connection at your VSS. You could try unplugging it and cleaing your connections. If it was ever unplugged, make sure the plugs are straight and none of them are bent. HTH.
kyriian
Jan 29, 2012 10:37 PM
m0nee
Honda Civic (2006 - 2015)
Apr 1, 2008 07:05 PM
sensorsearch
Aug 18, 2004 04:52 PM
sparknblaze
Feb 5, 2003 03:47 PM
