Pros & Cons of a Type R.
Old May 11, 2005 | 05:21 AM
longjon85's Avatar
Default Pros & Cons of a Type R.
Just wondering what the pros an cons of a type r. Your advice will help me determine if i should look into buying it.
Old May 11, 2005 | 08:35 AM
mmuller's Avatar
Mad Scientist
Default Re: Pros & Cons of a Type R. (longjon85)
mmmm, could this be more vague?
what do you exactly want to know?
cons compared to what?
Old May 11, 2005 | 09:10 AM
longjon85's Avatar
Default Re: Pros & Cons of a Type R. (mmuller)
I basically want to know what kind of problems people have encountered with it. Or positive notes on how it performs. Like wat kinds of mods are good for the motor itself to get the full potential out of the motor.
Old May 11, 2005 | 11:14 PM
ReV LiMiT's Avatar
pros: its only a 1.8 liter, its got 200 hp, its pretty good on gas (compared to alot of them v8 guys), its hand built in japan, virtually compatible to any civic or integra, it comes with a port and polish from the factory, the trannys come with LSD, the cams are big, and its compression is high but no high enough to where you cant boost a stock one
con: its f*ckin expensive.....
hows that little run down for ya.....
Old May 11, 2005 | 11:24 PM
k00lt1nt's Avatar
Default Re: Pros & Cons of a Type R. (9d DA6 TEG)
true dat...!! for the price of a itr swap you can build a b20 beast!!! tiiteeee !!
Old May 12, 2005 | 12:22 AM
CRXDrew's Avatar
con: thief MAGNET...
Old May 12, 2005 | 07:05 AM
ReV LiMiT's Avatar
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k00lt1nt &raquo;</TD></TR><TR><TD CLASS="quote">true dat...!! for the price of a itr swap you can build a b20 beast!!! tiiteeee !!</TD></TR></TABLE>
screw that... with the 5000 for the itr swap, id find the mintest LS engine and boost the ever living **** out of it lol.....talk about bang for buck hahahaha
Old May 12, 2005 | 09:10 AM
longjon85's Avatar
Default Re: (9d DA6 TEG)
very helpful comments
Old May 12, 2005 | 11:28 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: (longjon85)
your not gonna want to drive it anywhere because your gonna be worried abought door dings getting jacket or rackin up the milage
Old May 12, 2005 | 03:58 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">con: thief MAGNET... </TD></TR></TABLE>
its a sad, sad truth.......
Old May 12, 2005 | 07:43 PM
T4eg's Avatar
Like stated above the ONLY con on the ITR is the price tag
Old May 14, 2005 | 03:22 AM
StorminMatt's Avatar
Default Re: Pros & Cons of a Type R. (T4eg)
Pros of ITR motor:
1. 200HP bone-stock.
2. In spite of the above, it actually responds well to further upgrades (i/h/e, cams, increased displacement, etc.)
3. Virtually indestructable
4. Great fuel economy
5. As stated before, compression is high enough for good cams, but not too high for pump gas
6. An easy swap. MUCH more simple than trying to get the same power from something else
Cons of ITR:
1. Price. Although you could easily spend just as much trying to extract the same power from a lesser motor
2. Thief magnet
aLlm0t0rboY
K Series
13
Aug 18, 2010 09:15 AM
ekjoker
10
Apr 28, 2009 08:06 PM
hatchbackjo01
26
Mar 3, 2009 05:50 PM
CleanSiR
Sep 30, 2008 06:42 PM
matty413
Sep 21, 2005 09:01 PM
