Fixing 3rd gear grind - what to buy
Need to fix horrible 3rd gear grind. It used to be barely noticeable, but then one weekend I installed a prolite flywheel, jimfab mounts, and a stage 3 clutch and the grind became so narly that I have to double clutch going into 3rd.
So after reading the archives, most people recommend buying a whole gear set to fix the grind because you can't buy just synchros. But you also know that gearspeed sells just the synchros for $100.
So do I only need to buy the synchros or should I buy the whole gear set? And what about those "tranny rebuild kits" that include the two main bearings and seals? What are the odds that I even need to replace the bearings? Those suckers are expensive.
I'm hoping I can just buy the synchros and be done with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote"> It never hurts to replace bearings and seals.</TD></TR></TABLE>
Well it hurts my bank account
I'm just thinking along the lines of "if it ain't broke, don't fix it." And so far I haven't noticed any problems with the bearings. I guess I'll just crack the tranny open and see how things look. I can take my time to order what I need because I've got a z6 tranny I can throw in my car when I pull the y8 out.
kaj
Transmission & Drivetrain
Oct 31, 2010 07:57 PM
iBrandon
Aug 23, 2007 12:17 AM
dpine
Feb 26, 2007 07:06 PM
CPR
Dec 16, 2005 10:38 PM
