Hondata support 1600cc injectors?
Old May 10, 2005 | 10:18 PM
V-SPEC 1's Avatar
Default Hondata support 1600cc injectors?
I want to know if anyone have this setup and want to know if it idles rough. I have not seen anyone on here that uses 1600cc injectors w/ the Hondata. What do you guys recommend to use for a good fuel management? thanks guys.
Old May 10, 2005 | 10:23 PM
SFWD 1934's Avatar
Default Re: Hondata support 1600cc injectors? (V-SPEC 1)
HONDATA can run it. Sometimes you can get a decent idle, at a tad higher rpm, not outrageous. Other times we get it fluxuating between 1200-1800 rpm, not to to bad.
Good luck,
Jason
Old May 10, 2005 | 10:43 PM
V-SPEC 1's Avatar
Default Re: Hondata support 1600cc injectors? (SFWD 1934)
Old May 10, 2005 | 11:05 PM
mtber's Avatar
Hondata can do it. But AEM > Hondata
Old May 11, 2005 | 02:02 AM
HYBRID_H@TCH's Avatar
Default Re: Hondata support 1600cc injectors? (mtber)
Iam idling 1600's at 900 rpm with a 13.9 a/f on aem ems with aem injector driver..
I hear the aem injector driver can be used on next to any engine management..
Old May 11, 2005 | 03:01 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Hondata support 1600cc injectors? (99Hybrid_Hatch)
thats a lot of cc's....
Old May 11, 2005 | 03:43 AM
trentepic's Avatar
Default Re: Hondata support 1600cc injectors? (H.A.R.T B18C1EG6)
whats an injector driver? is that like some hardware or software?
Old May 11, 2005 | 05:47 AM
SFWD 1934's Avatar
Default Re: Hondata support 1600cc injectors? (trentepic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trentepic &raquo;</TD></TR><TR><TD CLASS="quote">whats an injector driver? is that like some hardware or software?</TD></TR></TABLE>
Here:
http://www.aempower.com/product_ems.asp
Check it out.
Jason
Old May 11, 2005 | 08:13 PM
trentepic's Avatar
seems similar to the resistor box, im sure its very different though
-Toby
Old May 11, 2005 | 08:24 PM
PrecisionH23a's Avatar
Weren't you running 1000cc's before? Just curious... what duty cycle were you at on the old set-up? Mase talks about your car like its the best thing since sliced bread, lol.
Old May 11, 2005 | 08:38 PM
Default Re: Hondata support 1600cc injectors? (PrecisionH23a)
who?
anyways..the aem injector driver is a true P/H driver that delivers a 4.1 amp current then drops it to a hold state of 1.1 amps to drive the low impedance injectors correctly..
I had to up my fuel value once I installed the driver and I dropped duty cycle at high boost aswell.. well worth the money to idle 1600cc like stock 240's...
Old May 11, 2005 | 09:18 PM
V-SPEC 1's Avatar
Yes, I was running 1000cc before and I don't know what DC I was at before. Mase never told me what it was. But I'm going to see if I can push the whp to around 650+ and I don't think 1000cc can handle it. I"m sure it can for some people on here, by raising the fuel pressure at the regulator but I don't like to push the small injector that much. I'd like to run around 85 ish duty cycle and not more.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">who?
I had to up my fuel value once I installed the driver and I dropped duty cycle at high boost aswell.. well worth the money to idle 1600cc like stock 240's... </TD></TR></TABLE>That's great. I'm glad to hear that . Anybody have any problem running this big injectors running on the street on the weekend?
Old May 11, 2005 | 09:23 PM
turtle-eg's Avatar
Bump, I wanna know too cuz' I'm running at 100% duty cycle on 1000cc
Old May 11, 2005 | 09:59 PM
Default Re: Hondata support 1600cc injectors? (turtle-eg)
I drive mine every other day to take the kids to school and to the store..drives great..
Old May 11, 2005 | 10:05 PM
turtle-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I drive mine every other day to take the kids to school and to the store..drives great..</TD></TR></TABLE>
What is you idle speed set at? Also how is it during a cold morning startup, would it stall a few times without holding the gas pedal down for a little bit let the engine warm up and clear the extra fuel?
Old May 11, 2005 | 10:11 PM
idle is at 900 rpm's and no..I dont give it any gas or touch the pedal at all during warmup..ems has alot of adjustability for this..
mkw1
Jan 9, 2008 05:24 PM
sloboy_joe
32
Nov 15, 2004 03:43 PM
B18C1_T
Oct 26, 2003 06:40 AM
BoostedH23a1
Sep 16, 2003 11:59 PM
LS-T
Mar 21, 2003 11:21 PM
