Vtec not working
Old May 10, 2005 | 10:18 PM
hybridnorth's Avatar
Default Vtec not working
I got my head rebuilt a few weeks ago, installed it all this past weekend, took it out for a drive and im not hitting vtec, no codes, got tons of oil pressure, vss is working fine.
I cleaned out the filter on the solenoid, it did have some metal shavings in it.
It worked fine before the rebuild
B16 bottom end
GSR head
also I added some comp cams, but no cross over
any ideas?
Old May 11, 2005 | 11:15 AM
Default Re: Vtec not working (hybridnorth)
anyone?
Old May 11, 2005 | 11:47 AM
92Jspec's Avatar
did you try swapping the vtec solenoid with a different one?
Old May 11, 2005 | 01:11 PM
Default Re: Vtec not working (92Jspec)
im gonna try that tonight
is there anything inside the solenoid that needs to be cleaned besides the filter?
Old May 11, 2005 | 01:42 PM
92Jspec's Avatar
just the wire screen is all i can think of. is your vtec wired straight to the ecu? or are you running a vtec harness? check for loose wire connections.
Old May 11, 2005 | 01:52 PM
killerbseries's Avatar
Man I feel sorry for you..I have the same problem got my head back from machine shop..vtec worked but made a clicking noise at changeover..then vtec stopped working...so I took my head off put stock b16 head on and still does it then goes away after..nothing but a headache..almost want to sell my car
Old May 11, 2005 | 02:04 PM
johnzm's Avatar
Default Re: (killerbseries)
sell it to me
i am currently doing my cars with a 1 wire VTEC, i turn off every sensor, and just wire the solenoid. works like a charm
A4 bitches.
Old May 11, 2005 | 03:40 PM
factory harness out of a si, wire's are ok, but ill check again
vss might be out of a d-series, or something, cause the bolt hole dosn't line up with the hole in the tranny
Old May 11, 2005 | 03:43 PM
92Jspec's Avatar
well if the bolt hole doesn't line up then maybe the vss isn't working properly since its not mounted properly........just a thought. good luck though
Old May 11, 2005 | 10:17 PM
hey got it too work
haha actually it was working the whole time, engagment was soooo smooth
that and i havnt driven anything with any power in 10 months, i think i lost the feel for it
also when i drove it, the exhaust hanger broke, and it was all distorted
go figure haha
thanks guys
Old May 12, 2005 | 07:57 AM
92Jspec's Avatar
hahahaha..... good shiet at least you now it works now!
Old May 12, 2005 | 08:26 AM
haha yea, i got a chipped p28 with a 5700 x-over
i was playing around out in the farm area to my hidden test track, and there's no way i would be doing that kind of speed in that short of distance hehe
thanks guys, this soul has been needing vtec for a long time, and it finally got it!
ill post pics and times asap
TWINK1E
15
Apr 28, 2011 03:53 PM
civictildeath
Aug 2, 2006 08:22 PM
Suck my DX
Jan 6, 2005 10:34 AM
jdmsijdm
Jul 12, 2004 11:51 AM
