Honda S2000 Honda S2000
Drag Race s2000 60 ft times
Old May 10, 2005 | 09:11 PM
rice is nice's Avatar
Default Drag Race s2000 60 ft times
What is the weight of your car? Hp level, and 60 foot time?
I'm just curious what s2000's can get for 60 foot times, and how that compares to FWD hondas in drag racing. Also curious what you guys think about 60 foot times on the street, and if the strip times are anywhere near what the street 60 foots would be.
Old May 10, 2005 | 10:53 PM
Bs2000's Avatar
Default Re: Drag Race s2000 60 ft times (Killa-X)
my 60foot stock s2k 2005 at palmdale Ca. 2710ft above sea leave was 2.277 best was 2.200.
Old May 11, 2005 | 04:58 AM
SuzukaBlueAP2's Avatar
Default Re: Drag Race s2000 60 ft times (Bs2000)
Just 2.2? I would guessed that it would've been lower than that. but, there are variables in it.
Old May 11, 2005 | 06:57 AM
Sideways's Avatar
2550lbs. , 400+ hp, 1.78 sec 0-60 gtec pro. I haven't been to the track yet.
If you only want to drag race then change out the rearend and axles and have fun.
Greenlight (on s2ki) just set a new drag race record down in Texas with a F20C powered dragster. This indicates the potential of the engine. Can you imagine dumping the clutch at 9500 and never going below 9000 rpm. Shifting at 11,500 or so?
Old May 11, 2005 | 07:27 AM
blkturbos2k's Avatar
Default Re: Drag Race s2000 60 ft times (Sideways)
Where did you get the 2550lbs from? You must of lost alot of lbs. The best 60ft that I got was 2.0 I was running on shitty kumhos. What was your 1/4?
Old May 11, 2005 | 08:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways &raquo;</TD></TR><TR><TD CLASS="quote">2550lbs. , 400+ hp, 1.78 sec 0-60 gtec pro. I haven't been to the track yet.
Greenlight (on s2ki) just set a new drag race record down in Texas with a F20C powered dragster. This indicates the potential of the engine. Can you imagine dumping the clutch at 9500 and never going below 9000 rpm. Shifting at 11,500 or so? </TD></TR></TABLE>
Sounds like Erik Aguilar with his close ratio b series tranny.
What tranny, or where did greenlight get the gears to only drop 2500 rpm per shift?
Old May 11, 2005 | 09:37 AM
mrS2K's Avatar
i got 2.186 for my 60 ft 13.8 quarter mile bone stock
Old May 11, 2005 | 09:58 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways &raquo;</TD></TR><TR><TD CLASS="quote">Greenlight (on s2ki) just set a new drag race record down in Texas with a F20C powered dragster. This indicates the potential of the engine. Can you imagine dumping the clutch at 9500 and never going below 9000 rpm. Shifting at 11,500 or so? </TD></TR></TABLE>
What was the new record?
Old May 11, 2005 | 10:05 AM
Sideways's Avatar
Default Re: Drag Race s2000 60 ft times (RyanCivic2000)
http://www.s2ki.com/forums/ind...59&hl=
It's in this post.
Old May 11, 2005 | 10:30 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways &raquo;</TD></TR><TR><TD CLASS="quote">http://www.s2ki.com/forums/ind...59&hl=
It's in this post.</TD></TR></TABLE>
Thanks.
Old May 11, 2005 | 11:17 AM
fknfast's Avatar
2.1 bone stock
Old May 11, 2005 | 11:18 AM
fknfast's Avatar
gtec pro
throw that junk out the window.
Old May 11, 2005 | 11:41 AM
Shift@9k's Avatar
Default Re: Drag Race s2000 60 ft times (fknfast)
i ran a 2.6 60ft. wiht 240whp and went on to run a 13.6@110 when i get the 60ft. cut down this weekend be very affraid
P.S. i know a turbo s2k W/450whp is more then cappaable of a 1.6 60ft and i know cause its been done
Old May 11, 2005 | 11:56 AM
Default Re: Drag Race s2000 60 ft times (Shift@9k)
This weekend? What dont I know? Will it be done?
Old May 11, 2005 | 03:37 PM
BOOSTEDS2K's Avatar
Default Re: Drag Race s2000 60 ft times (blkturbos2k)
weel my car should be done n a week or 2... shooting for 700-725 hp so when its all done i will let you know what kind of 60fts i will have !! but my best so far on 15psi was 2.025 I went 12.1 @117 on some junk *** yokohama tires!! should hit low low low 11's 1ft time down the track and will hit 10's this summer too!!
Old May 12, 2005 | 05:18 AM
Toolman's Avatar
damn a 13.6 at 110 that is a **** run.. get that 60 foot down you will will see 12s for sure..
Old May 12, 2005 | 07:32 AM
CHEETAH's Avatar
with stock wheels and tires, I've actually gotten some 2.0's and 2.1's ... have Work Emotion R 17's with stock BMW M3 tires and can only muster 2.2s and 2.3s
My s2k with me was a cinsistent 2985 lbs ... lol I call it an S3K
Greg
Old May 12, 2005 | 10:27 AM
Francesco's Avatar
Default Re: Drag Race s2000 60 ft times (BOOSTEDS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDS2K &raquo;</TD></TR><TR><TD CLASS="quote">weel my car should be done n a week or 2... shooting for 700-725 hp so when its all done i will let you know what kind of 60fts i will have !! but my best so far on 15psi was 2.025 I went 12.1 @117 on some junk *** yokohama tires!! should hit low low low 11's 1ft time down the track and will hit 10's this summer too!!</TD></TR></TABLE>
jeez...keep us posted and good luck
Old May 12, 2005 | 01:19 PM
Nishant's Avatar
Default Re: Drag Race s2000 60 ft times (Francesco)
lowest stock i have seen is 2.0xx, nothing in the 1.9's but someone may have
Old May 13, 2005 | 07:20 PM
SwpR's Avatar
Default Re: Drag Race s2000 60 ft times (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Just 2.2? I would guessed that it would've been lower than that. but, there are variables in it. </TD></TR></TABLE>
how can you improve the 60ft time on the car?
Old May 13, 2005 | 09:34 PM
Default Re: Drag Race s2000 60 ft times (SwpR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwpR &raquo;</TD></TR><TR><TD CLASS="quote">how can you improve the 60ft time on the car?</TD></TR></TABLE>
Well, quick reaction times will help, but, aside from that, playing with tire pressures and stickier tires may help. Just becareful of that rear diff. You don't want to break it from a launch that is too hard.
Old May 14, 2005 | 07:46 PM
honda9krpm's Avatar
my best was 2.3 because I've always been gentle on the diff
my worst was this
http://img.photobucket.com/alb...7.jpg
snapped axle and broke the gearbox at 3700rpm launch....thanks Honda for the weakness and inevitible
btw when do you need to have a full roll cage, parachute etc etc in the US? Is it in the 10 or lower?
Modified by honda9krpm at 10:12 PM 5/14/2005
Old May 14, 2005 | 08:25 PM
Nishant's Avatar
Default Re: (honda9krpm)
i know the local tracks require cage for 12 and under
Old May 14, 2005 | 08:47 PM
Default Re: (Nishant)
Yeah, I don't know if there is a national time where a cage must be employed. Some tracks only require a roll bar at 12.xx.
It'd be best to contact the track you'll be competing at for this info. And if you already know that you'll be making 9.xx passes...you might as well get an NHRA spec cage.
slayer423
Mar 22, 2013 03:40 PM
95ITRJDM
Dec 9, 2011 12:16 PM
Sliced Beard
Honda Motorcycles
27
May 2, 2008 09:01 PM
RACEPAK
Dec 18, 2005 08:15 AM
