1994 Accord won't start
Okay, I've been driving around my car all day, I bring it home, shut it off, then remember I have one more errand to run. I turn over and nothing. Lights, radio, dash etc all work. When I turn the key I hear nothing except a humming sound.
I'm thinking its either the starter or wiring to the starter.
Where is the starter located on a 1994 Accord EX (Automatic)? And where is the main relay and starter relay? If someone had a diagram or something, that'd be awesome as I am pretty retarded when it comes to this sort of stuff but I'd hate to pay a mechanic to do something as simple as clean a wire.
Thanks
Thanks
sounds like a starter or battery , cables sort of problem, starter is on top of tranny follow positive battery cable ,,try a little test have someone hold the key in the start positon and bang on the starter with a big screwdriver ot a metal pipe if it cranks there is your problem....also make sure all your battery cables are tight and not corroded
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_EmO »</TD></TR><TR><TD CLASS="quote">had the same problem on my 94... i just kept turning the key over and over then it finally started HAHAHA
lol, i think we have all resorted to this method at least once with our accords...
</TD></TR></TABLE>lol, i think we have all resorted to this method at least once with our accords...
man, i had the same problem but it turned out to be the wiring for my ignition which created the need for a new engine wiring harness. But yea, the starter seems to be the problem. Uhm, i suggest a Denso starter, not a Bosch.
lol i did the same, but it only happend once, and that was like 1 month ago
</TD></TR></TABLE>lol i did the same, but it only happend once, and that was like 1 month ago
happened to my car but i didn't have a humming noice, i ddint drive my car for one month because i was lazy to fix it. month later i realize it was just a main fuse....... pretty lazy huh. but check the starter as what them all say, i doubt it's the ignition
magpie.1234
Jul 24, 2015 02:19 PM
needhondahelp90
Nov 25, 2014 11:46 AM
ZexyAccord
Jan 9, 2006 03:34 PM
