need help Best way to install one piece header
Old May 10, 2005 | 07:44 PM
coot_er's Avatar
Default need help Best way to install one piece header
i have a b16 in my 91 hf. im trying to get the old stock header out so i can put in my new one piece. what is the best way to do it since i need to remove the cross member?
Old May 10, 2005 | 11:52 PM
Ef-er's Avatar
Default Re: need help Best way to install one piece header (coot_er)
i was able to squeeze mine in after removing the 4 bolts on bottom of cross member and 2 on the front for radias arms. just move the cross member a bit then should be easy to fit in
Old May 11, 2005 | 04:40 AM
Autoworks's Avatar
Default Re: need help Best way to install one piece header (ChineseGuy)
I agree, the only way to get a 1 pc. header on is thru the bottom, and you'll have to remove the crossmember.
Old May 11, 2005 | 12:21 PM
coot_er's Avatar
Default Re: need help Best way to install one piece header (Autoworks)
ya i know i have to remove the crossmember i just was wondering which way i should do it.
1. remove the 4 vertical bolts on the cross member and then just the 2 nuts on the front of the crossmember
2. remove the 4 vertical bolts on the cross member and then remove the shocks and axles so that i can access the four (2 on each side) bolts that bolt to the lower control arm?
Old May 11, 2005 | 02:08 PM
PURPLETERROR aka BIGMATT's Avatar
just unbolt the x member and drop it a few inches, that should give you more than anough room
Old May 11, 2005 | 02:27 PM
Rywire's Avatar
Default Re: need help Best way to install one piece header (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">just unbolt the x member and drop it a few inches, that should give you more than anough room</TD></TR></TABLE>
Exactly!
Old May 11, 2005 | 05:43 PM
coot_er's Avatar
Default Re: need help Best way to install one piece header (droppedcrxsi)
have you actually put in a one piece header only by lowering it like that. i will only allow the cross member to drop about 2 inches. will that be enough?
Old May 11, 2005 | 07:59 PM
coot_er's Avatar
so all i need to do i remove the 4 cross member bolts and lower it about 2 inches and thats it? im guessing that will just barley give me enough room for the new header to clear?
Old May 11, 2005 | 08:32 PM
Contender25
Guest
Posts: n/a
Remove the crossmember to install headers is alot more easy then takin out the motor "obviously". But anyways just try that first with a couple inch's off it and see if it fits.
Old May 11, 2005 | 08:49 PM
coot_er's Avatar
Default Re: (Contender25)
so "contender25" have you actually done this?
oh ya, go to profile at the top and check you instant message history from me. i still need some help with that problem.
Old May 11, 2005 | 11:22 PM
Contender25
Guest
Posts: n/a
I guess cause im new to the forums, it won't let me check instant messages. Well though go ahead and try what me and other people have been sayin about the crossmember, even if it drops only a few inch's or so, that should be enough to play with the room a little and clear it somehow. Nobody ever said it wasn't gonna be a pain in the ***, but i know you want them new headers on there.
Old May 11, 2005 | 11:26 PM
Rywire's Avatar
I have done it by lowering it with the radious rods still holdin on, yes it can be done.
Ryan
minilogoguy18
Dec 2, 2009 04:26 PM
type Gendy
17
Jan 4, 2008 08:14 AM
JDM_Acccord
Apr 24, 2007 02:00 PM
Agent STFU
Jul 24, 2003 11:09 PM
ophdehEEzY
Mar 5, 2003 09:02 AM
