Why am I rubbing with 205/55/15 Azenis?
I rub the tops of my wheel wells coming into my driveway. Not stock, but tires are a little too big too.
YMMV, or I guess not.
EDIT: Didn't click the pic to see what was really rubbing...
You need a spacer. Sucks, but yeah those are too tall. My 225/50 R15 Kumhos (way back in the day, and stock suspension) rubbed at full lock on stock wheels too. +5 mm should take care of it.
-Chris
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v0gueSilver_Dc2 »</TD></TR><TR><TD CLASS="quote">look smack dab in the middle of teh pics</TD></TR></TABLE>
Yeah, full lock, turning left, at the bottom inside of the wheel well.
CLICK on picture for bigger image.
I'm sure he meant 205/50/15 if he's talking about the Azenis. I've rubbed on that same spot, but raised the car up about half an inch and had no trouble. Not sure about what's causing it on stock ride height however.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">bc you should be using 205/50/15</TD></TR></TABLE>
^ what he said
^ what he said
if it rubs on the side, take a hammer and smack it in a bit, also take your fenderwells off, mines only rub on a full turn and it hardly does
you should see my spot, mines used rubbed so much at that hump that it turned it into metal lol
This is very strange. I (and many others) have zero rubbing with the 205/50/15 Azenis on lowered cars. What are your alignment settings?
I'm assuming you're running azenis on stock wheels?
You have too much bodyroll and too soft of springs + too much positive offset on wheels.....
Get stiffer suspension and 15x8 +27 te37's to fix this.....
The problem is that it's one of those fake black Type Rs....kidding.
I ran the same tires on my old ITR with stock supension and wheels and no problems.
No one has asked if you are still running stock wheels and or offset....that could affect it.
my 205/50/15 azenis rubs at the same spot on the left side tho (right side is ok, just little bit rub)
but my car was lowered, no wheel gap at the front with 15x6.5 +42 rims
with 1/8 inch higher, there is almost no rubbuing unless i do full lock left u-turn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 »</TD></TR><TR><TD CLASS="quote">if it rubs on the side, take a hammer and smack it in a bit, also take your fenderwells off, mines only rub on a full turn and it hardly does
I don't know exactly what my alignment settings are. I'm assuming everything is to stock specs. There is the same rub on the right side too.
Everything is stock; suspention, camber, alignment, wheels, everything.
